avital 4103, 05 ram
vige14
Member - Posts: 9
Posted: December 22, 2012 at 12:55 PM / IP Logged
Installed a rs1200 on a 05 ram . It works fine. But my brake light and ABS light stays on when it starts . The brake only shows red when the pedal is pressed. The hood pin shuts down the unit when opened. Also I noticed when I start it it doesn't start on the first try short crank, the second time it starts? Did not install tach wire,should I install it? How do I get the lights on the dash to go out?
smokeman1
Platinum - Posts: 1,589
Posted: December 22, 2012 at 1:12 PM / IP Logged
Which bypass did you use? and what remote start are you using?  You are confusing this post with Ram and Trailblazer info
pentavolvo
Copper - Posts: 241
Posted: December 22, 2012 at 1:19 PM / IP Logged
hook tach wire up and program for tach use will eliminate the two trys for start
as far as brake lighe/abs light did you hook up both ignition wires and the accessory wire
vige14
Member - Posts: 9
Posted: December 22, 2012 at 6:31 PM / IP Logged
Yes I did connect both ignition wires WHITE/ red and white from module to ignition 1 and ignition2 And the accessory wire WHITE/ black from module to blue on the truck. I have installed a RS 1200EP . Did not install bypass , no security system on this truck .I will install tach wire tomorrow.
Page of 3
