2010 acura tsx viper 4704
nathan1465
Member - Posts: 14
Posted: June 02, 2013 at 1:02 PM / IP Logged
I paired the remote again and now the Viper is working just fine. By fine I mean it will honk, flash the parking lights and open the trunk.
The bypass module I can't get to program correctly. Below are the steps I am taking, is there anything I am missing? The store I bought it from said they would flash it but I am wondering if it was flashed to the correct firmware. I never verified which firmware they were flashing it with just that it was the correct car. I am wondering if I am working off instructions for a different firmware or something.
Reset idatalink
-Disconnect all plugs except for the 4 pin black
-Disconnect black 4 pin pulg
-Hold programming button
-Plug black plug in
-The light blinks red quickly
-Release the button
-Plug all other connectors in (I have also tried waiting to do this until after the light starts blinking green below.
-Light goes solid red for a couple seconds
-Light starts blinking green
Program idatalink
-Press button
-double green LED indicating wire to wire mode
-press and hold
-solid green light for 2 seconds
-solid red light for 2 seconds
-slow red blink
-Key in ignition to on position
-Wait and nothing changes, same red blink
-Turned key to off, no change
-Tried pressing unlock on factory fob, no change
-It will stay with this red link with whatever I press or do until I reset the module
I have tried these steps with the drivers door shut and with the door open to the same result.
Platinum - Posts: 7,828
Posted: June 02, 2013 at 3:10 PM / IP Logged
It sounds like you are following the steps correctly. I do it a little differently. Try this.
Do the Factory Reset procedure but at step 5 wait for the LED to start doing the single flashes.
Press the button once and verify the LED starts doing the double Green flashes. Press and
hold the button . The LED will go solid Green for two seconds and then go out. Release the
button and reconnect all the harnesses. Then continue with the vehicle programming by
inserting the ignition key, switch to ON, etc. If it doesn't follow the guide exactly compare the
LED indication to the Module Diagnostics chart.
The ADS module only has 4 wire connections to the vehicle. Verify them and make sure they
are well soldered and insulated. The wire colors should match the iDatalink wire chart exactly.
It is very rare to get a bad module from iDatalink. It is possible that the shop flashed the wrong
firmware but the only way to tell is to use the ADS USB cable and check it online.
nathan1465
Member - Posts: 14
Posted: June 02, 2013 at 4:13 PM / IP Logged
I tried it again that way with no luck.
I reset it. Then I pushed the button until the double green. Then I hold the button until the light goes green for two seconds then goes out. If I keep holding nothing happens but as soon as I release the light turns to red for two seconds then goes to the slowly flashing red. I then connected the cable to the car and nothing changed.
The module diagnostics chart states "Missing/wrong information from firmware or vehicle".
I'm thinking the next step is sourcing a cable from somewhere online and checking the firmware.
The 4 wires to the ignition are soldered and wrapped in electric tape and I have double checked the wires with their diagram and checked the canh, canl and data wires with other charts online. I thought of testing the resistance between the plug at the ignition and the plug at the idatalink to verify the solder connection but I am concerned doing so could hurt the cars computer.
Posted: June 02, 2013 at 4:48 PM / IP Logged
Bummer... 2010 acura tsx viper 4704 - Page 2 -- posted image.
Beware that even with the ADS USB cable, you will have to register and be certified as a 12V Professional by iDatalink to check or download firmware.
nathan1465
Member - Posts: 14
Posted: June 02, 2013 at 9:43 PM / IP Logged
I was able to sign up online so hopefully it works out.
I forgot about something else though. The wire labeled as accessory 1, orange, didn't have 12v when the key is turned to accessory only when it was turned to ignition. But the wire went to 0v during crank just like the accessory 2 wire does. Sould I treat this wire as a 2nd accessory or 2nd ignition? It is acting like a combination of both. I hooked it to the flex and I was planning on it triggering with the accessory so it would lose power during crank.
Accessory 2, white, on the other hand has 12v in the on position and the accessory position.
Posted: June 02, 2013 at 10:02 PM / IP Logged
I go by the drop during cranking to classify ignition wires. Set it up as an Accessory wire. It should not have any effect on the bypass programming.
Just for grins, you could try swapping the CanH and CanL wires, but the wire info from iDatalink is always spot-on.
Also double check to ensure that the ADS AL CA Blue/White GWR wire is connected to the Vipers Dark Blue (-) 200mA Status Output and not the Vipers GWA wire. It should be OK, that's the way you had it listed originally.
nathan1465
Member - Posts: 14
Posted: June 02, 2013 at 10:08 PM / IP Logged
By trigger it with accessory mean just set the flex relay to accessory.
Posted: June 03, 2013 at 5:05 AM / IP Logged
Correct. Set Menu 3, Item 8 to Option 2.
nathan1465
Member - Posts: 14
Posted: June 16, 2013 at 9:21 PM / IP Logged
I got the cable and sure enough it had the wrong firmware on it, I flashed it to the right firmware and the idatalink programming worked without issue. The only problem I am having now is that the trunk release I hooked up to requires all of the car doors to be unlocked to work so it won't pop the trunk when the car is locked. I did notice that when I press the trunk it does do unlock at the same time but it does it just once and only unlocks the drivers side door. If I press trunk again all doors unlock like progressive unlock and the trunk will open. I am a little confused why it is unlocking any doors during trunk pop though, it should just be disarming the alarm. Maybe that is how the idatalink disarms the alarm by a single unlock?
Posted: June 16, 2013 at 9:41 PM / IP Logged
I noticed the same thing on a Lexus recently. That is a totally different setup. Here is
what I would do / try. Being as the bypass module handles the trunk thru CAN Data and
it can't pop the trunk while the car is remote started, bypass the bypass and connect the
Viper's Trunk Release (-) output directly to the car. Here is the wire info :
Trunk/Hatch Release   Pink (rear handle switch) (-) @ driver dash fuse box, Lt. Green 20 pin plug, pin 3
That way the trunk will release will work all the time and as long as the Viper sends a Disarm
to the iDatalink and the idatalink passes that command to the car thru the CAN Data....
Page of 3
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
