viper 5704v on manual transmission
mikklo
Member - Posts: 10
Posted: July 03, 2013 at 2:01 PM / IP Logged
I have installed my new viper 5704 on my 96 mitsubishi eclipse and was really excited but am having a little difficulty. Everything seems to be working fine except when I go through "reservation" at the end the remote start does activate but then when I turn the key off the engine turns off and the remote starts disables. Please help!
Posted: July 03, 2013 at 9:51 PM / IP Logged
Show your wire connections, have you prgrammed tach?
mikklo
Member - Posts: 10
Posted: July 05, 2013 at 11:47 PM / IP Logged
Wiring Connections
Main Harness, 6-pin Connector
H1/1 Red(+)12VDC Constant Input connected to white(+)12 Volt Constant
H1/2 Black(-)Chassis Ground connected to Car Chassis Ground
H1/3 Brown(+)Siren Output connected to th Siren
H1/4 WHITE/ Brown Parking Light Isolation Wire-Pin 87a of onboard relay not connected
H1/5 White Parking Lights Output connected to GREEN / WHITE(+)Parking Lights
H1/6 Orange(-)500mA Ground When Armed Output not connected
Remote Start, 10-Pin Heavy Gauge Connector
H3/1 Pink(+)Ignition 1 Input/Output connected to BLACK/ White(+) Ignition 1
H3/2 RED / White(+)Fused (30A) Ignition 2/Flex Relay Input 87 not connected
H3/3 Orange(+)Accessory Output connectd to Blue/Black(+)ACCESSORY /HEATER Blower 1
H3/4 Violet(+)Starter Output connected to BLACK/ Red(+)Starter Car Side
H3/5 Green(+)Starter Input connected to BLACK/ Red(+)Starter Key Side
H3/6 Red(+)Fused(30A)Ignition 1 Input connected to BLACK/ White(+)Ignition 1
H3/7 Pink/White(+)Ignition 2/Flex Relay Output not connected
H3/8 Pink/Black(+)Flex Relay Input 87a Key Side (if reqired) of Flex Relay not connected
H3/9 RED / Black(+)Fused(30A)Accessory/Startr Input not connected
H3/10 No Connection
Auxiliary/Shutdown/Trigger Harness, 24-Pin Connector
1 Pin/White(-)200mA Ignition 2/Flex Output not connected
2 Blue/White(-)200mA 2nd Status/Rear Defogger Output not connected
3 RED / White(-)200mA Trunk Release Output not connected
4 BLACK / YELLOW(-)200mA Dome Light Output connectd to RED / Green(-)Door Trigger
5 Dark Blue(-)200mA Status Output not connected
6 WHITE/ Black(-)200mA Aux 3 Output not connected
7 WHITE/ Violet(-)200mA Aux 1 Output not connected
8 ORANGE / Black(-)200mA Aux 4 Output no connected
9 Gray(-)Hood Pin Input connected to Hood Pin
10 Blue(-)Trunk Pin/Instant Trigger Input not connected
11 WHITE/ Blue Activation Input not connected
12 Violet/White* Tachometer Input conneced to White Tach
13 BLACK/ White**(-)Neutral Safety/Parking Brake Input conneced to Parking Brake
14 GREEN/ Black(-)200mA Factory Alarm Disarm Output not connected
15 Green*(-)Door Input connected to RED / Green(-)Door Trigger
16 BROWN / Black(-)200mA Horn Honk Output connected to GREEN/ Black(-)Horn
17 Pink(-)200mA Ignition 1 Output not connected
18 Violet*(+)Door Input not connected
19 Violet/Black(-)200mA Aux 2 Output not connected
20 Brown(+)Brake Shutdown Input connected to GREEN / WHITE(+)Brake
21 Violet / YELLOW(-)200mA Starter Output not connected
22 Gray/Black(-)Diesel Wait to Start Input not connected
23 Orange(-)200mA Accessory Output not connected
24 GREEN / WHITE(-)200mA Factory Alarm Arm Output not connected
*Required connection for manual transmission vehicles.
**Ground this wire for automatic transmission vehices or connect to the parking brake wire for manual transmision vehicles.
mikklo
Member - Posts: 10
Posted: July 05, 2013 at 11:49 PM / IP Logged
Also yes I have programmed the tach and even though it comes in manual mode from factory I have made sure it is in manual mode. Thank you very much for the help really do appreciate it!
Posted: July 06, 2013 at 3:09 AM / IP Logged
Connect H3/2 RED / WHITE and H3/9 RED / BLACK to 112V+ constant source.
Don't worry EVERY beginner makes that mistake. It's called RTFM.
mikklo
Member - Posts: 10
Posted: July 06, 2013 at 7:21 AM / IP Logged
Allright thank you, I will definitely do it as soon as I get home from work tonight. Also I wanted to ask what a couple things did like as far as the GROUND WHEN ARMED OUTPUT? Is it neccessary? Dome light can be connected to the door trigger correct? How does the thrunk release output work? Number 18 in the 24-pin show it has to be connected since it is a manual transmission as was wondering if I just connect number 15 is that ok?
Posted: July 06, 2013 at 7:45 AM / IP Logged
GWA not needed unless you have a tilt sensor.
D0 you have two starter wires? That's when you need H2/18. It triggers a relay for a second starter wire. NOTHING to do with a manual transmission.
Trunk release, I've no info, TEST at the switch.
How many wires, NEG (-) from the switch? POS (+) from the switch? TEST
Ref. the dome light, again read the instructions.
mikklo
Member - Posts: 10
Posted: July 06, 2013 at 9:12 PM / IP Logged
So I did as you said connected H3/2 RED / WHITE and H3/9 RED / BLACK to 112V+ constant source but still is not enough the remote start still dies after putting it in reservation mode and taking out the key.
mikklo
Member - Posts: 10
Posted: July 07, 2013 at 8:49 PM / IP Logged
I tried programming the tach again and it seems to not be reading it may I have the wrong wire for the tach? Do you know which one it is and where is it located because I tried where bulldogsecurity.com says in the ECU plug the white wire.
Posted: July 08, 2013 at 2:23 AM / IP Logged
Did you test the white wire?
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
