viper 4704 no start
perfecthrasher
Member - Posts: 19
Posted: July 13, 2013 at 10:57 PM / IP Logged
Finally I had time to go back and finish 4704 install on my 2008 Nissan rogue key fob type vehicle. My issue is the starter doesn't turn over checked my grounds etc. What i've found is that there is no power to the starter wire at the ignition plug when I attempt a start. There is approx. 12 volts when I use the key fob what I'm I missing?
Thx
Posted: July 14, 2013 at 2:55 AM / IP Logged
The heavy duty plug; is there a red, RED / white and RED / black? Are they all connected to a heavy duty (such as ignition loom supply wires) constant?
Has tach been programmed?
perfecthrasher
Member - Posts: 19
Posted: July 14, 2013 at 1:17 PM / IP Logged
I did not connect the RED / white RED / black based on my reading for this vehicle on the forums. I just completed the RED / white RED / black connections redid the tach run and programmed the tach. The vehicle will now turn over (and run) BUT only with the key in the tumbler I gather I have a bypass issue now?
offroadzj
Gold - Posts: 2,043
Posted: July 14, 2013 at 2:41 PM / IP Logged
Yup. What bypass did you use?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
perfecthrasher
Member - Posts: 19
Posted: July 14, 2013 at 3:14 PM / IP Logged
Idatalink ads-al
mmain1
Member - Posts: 17
Posted: July 18, 2013 at 9:58 AM / IP Logged
I'm not sure if you are using D2D or W2W. If you are using W2W did you connect the Ground While Running input to the Dark Blue Status Output wire?
perfecthrasher
Member - Posts: 19
Posted: July 18, 2013 at 8:38 PM / IP Logged
I'm doing D2D, I can program the bypass but the led is off during remote start attempt (invalid ground when running status from remote starter). Based on the guide 9473 I connected the solid black lines only so no status output wires have been connected.
Platinum - Posts: 7,827
Posted: July 19, 2013 at 6:58 AM / IP Logged
If running D2D mode to a Viper 4704, was / is the iDatalink bypass module flashed with the DBI flavor of firmware ( not the ADS flavor )?
perfecthrasher
Member - Posts: 19
Posted: July 23, 2013 at 8:14 PM / IP Logged
flashed iDatalink 2-way DL-NI4
Posted: July 23, 2013 at 8:50 PM / IP Logged
Still not sure if you have the correct firmware.
DBI-AL(DL)-NI4 for ADS-AL CA bypass module is the correct firmware for D2D with a Viper unit.
ADS-AL(DL)-NI4 for ADS-AL CA bypass module will not work D2D with a Viper unit.
Either will work in W2W mode.
Thursday, September 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
