2002 Rav4, prestige aps997e installation
skchoppala
Posted: February 15, 2016 at 12:07 PM / IP Logged Link to Post Post Reply Quote skchoppala
Hi, I have started wiring Audiovox APS997E and struck figuring out few things. I really appreciate your help in advance
I have my car with dome light stays one few seconds or turns off as soon i lock the doors with factory key less entry. How to connect this? Install doc says "This wire provides a 30 second ground output, (300 mA Max.)" Do i have to use Relay?
Parking Lights: I have my security system provided with Parking Light Relay Input wire and Output Wire. How to make these connections with rav4 GREEN (+) as per the wiring diagram?
Ground Output While Running (-) 300mA: The mode i am trying to use is " Anti-Grind Starter Circuit Connection". The Installation manual referring to use relay. Does it really required? or rav4 starter wire will come from default relay?
Posted: February 15, 2016 at 1:27 PM / IP Logged Link to Post Post Reply Quote howie ll
a) Not needed your vehicle has built in dome supervision, you just described it!
b) Input must go to a 12V+ constant source.
c) Shouldn't be needed.
skchoppala
Posted: February 15, 2016 at 1:41 PM / IP Logged Link to Post Post Reply Quote skchoppala
Hi howie,
Thanks for the quick replay,
My uderstanding about Anti-Grind is to stop cranking the engine through key when car is started with remote. Will it not damage the starter with out connecting this wire?
Posted: February 15, 2016 at 3:38 PM / IP Logged Link to Post Post Reply Quote howie ll
Some vehicles have built in anti-grind, I'm not familiar with the R/Start so I suggest you contact Voxx.
skchoppala
Posted: February 15, 2016 at 3:47 PM / IP Logged Link to Post Post Reply Quote skchoppala
I did through test by turning key from start to crank while engine is running... it did make a wired sound. I hope it does not have automatic grind option. any how i will check with Voxx company as you suggested. Thank you very much for your help.
skchoppala
Posted: February 24, 2016 at 10:23 AM / IP Logged Link to Post Post Reply Quote skchoppala
Finally i have done with my installation and every thing works fine. Howie II thanks for your inputs. I did call customer car regarding my third question( Anti-Grind Starter Circuit Connection) and made the connection with relay provided in the kit. But i did not see its stop sending the signal to starter when the engine is started with remote. I may have to call back cust care.
