Toyota Supra Remote Start Viper 5706v
golfer2000
Member - Posts: 29
Posted: December 16, 2016 at 8:14 PM / IP Logged Link to Post Post Reply Quote golfer2000
I've managed to find 95 percent of the wires for the install but the horn, disarm, and hood wires elude me. I found the blue red for the horn in the steering column but it's not the horn trigger. In fact I tried all the blue wires and non are it. I can't find the theft ECU in the passenger kick panel at all and there are several white wires in the driver kick panel for the disarm but no unlock. Can anyone help me out with location these three connections? Thanks!
golfer2000
Member - Posts: 29
Posted: December 16, 2016 at 8:15 PM / IP Logged Link to Post Post Reply Quote golfer2000
It's a 1994 non turbo auto toyota supra if it matters.
golfer2000
Member - Posts: 29
Posted: December 18, 2016 at 2:08 AM / IP Logged Link to Post Post Reply Quote golfer2000
Also I believe I may have some wires wrong on my heavy gauge harness as I seem to have a large parasitic drain. Can anyone verify?
Toyota Supra Remote Start Viper 5706v -- posted image.
Per downloads chart:
golfer2000
Member - Posts: 29
Posted: December 18, 2016 at 2:12 AM / IP Logged Link to Post Post Reply Quote golfer2000
My chart got compressed pretty bad when uploaded so if you cant read the text: https://drive.google.com/file/d/0By1NhbvLzu-9VFVHR01UNXRjcWc/view?usp=sharing
golfer2000
Member - Posts: 29
Posted: December 19, 2016 at 11:10 AM / IP Logged Link to Post Post Reply Quote golfer2000
Anyone? My biggest concern is the heavy gauge harness if anyone can help with that.
smokeman1
Platinum - Posts: 1,589
Posted: December 19, 2016 at 5:11 PM / IP Logged Link to Post Post Reply Quote smokeman1
From your Heavy Gauge Harness:
Red, RED / White, and RED / Black should all go to a 12 volt constant source. In your listing, White or WHITE/ Red.
golfer2000
Member - Posts: 29
Posted: December 19, 2016 at 5:33 PM / IP Logged Link to Post Post Reply Quote golfer2000
Thank you. Can you comment on pink, pink/white and the others?
smokeman1
Posted: December 19, 2016 at 6:22 PM / IP Logged Link to Post Post Reply Quote smokeman1
They looked ok going by the wire listing. You should test your wires prior to making connections. Solder the connections.
golfer2000
Member - Posts: 29
Posted: December 19, 2016 at 10:58 PM / IP Logged Link to Post Post Reply Quote golfer2000
Can you explain why the RED / White which is for the ignition 2 (presumably only on during on and cranking) goes to a constant?
smokeman1
Posted: December 20, 2016 at 9:23 AM / IP Logged Link to Post Post Reply Quote smokeman1
So that it can supply a 12 volts through the Viper to the Pink/White wire.
Page of 4
Saturday, October 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
