Python 4806P w/ DBALL2 Module Programming Issue
beegbie
Copper - Posts: 341
Posted: September 13, 2017 at 7:53 PM / IP Logged Link to Post Post Reply Quote beegbie
2nd starter wire is needed on many older Nissans but not on this one. If you look at a factory diagram for the 2014 x-terra, the second starter wire in the ignition harness doesn't actually do anything. It doesn't connect to anything in the car.
abethebue
Member - Posts: 26
Posted: September 21, 2017 at 12:41 AM / IP Logged Link to Post Post Reply Quote abethebue
You need to connect the red white heavy gauge power cable to a 12v souce i didnt see that wire in your ignition harness wiring and if the parking lights are flashing after you activate the remote start that is normal it means the remote start is on if connecting the red white wire doesn't work make sure you have power on your red black heavy gauge 12v +
abethebue
Page of 3
Tuesday, July 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
