2018 Nissan Rogue Head Unit Wiring
amriy152
Member - Posts: 6
Posted: June 30, 2018 at 3:03 PM / IP Logged Link to Post Post Reply Quote amriy152
Hello i am trying to connect a clarion 755 equalizier and would greatly appreciate if someone coild tell me the remote wire, constant 12v and a speaker signal L and R
Platinum - Posts: 13,726
Posted: June 30, 2018 at 6:10 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Have you installed an aftermarket amplifier in the vehicle already?
amriy152
Member - Posts: 6
Posted: June 30, 2018 at 6:27 PM / IP Logged Link to Post Post Reply Quote amriy152
Yes im leaving stock bose system just adding a voice box and sub in the back but i will need to connect this eq for audiosignal and remote wire
Posted: June 30, 2018 at 7:31 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Left Front Speaker - With Amp      Brown - Pink (woofer); White - Gray (tweeter)      +,-      Amplifier under passenger seat, brown 14 pin plug, pins 9 - 10; 11 - 12
Right Front Speaker - With Amp      Green - Red (woofer); Green - Red (tweeter)      +,-      Amplifier under passenger seat, brown 14 pin plug, pins 13 - 4; brown 23 pin plug, pins 10 - 23
Left Rear Speaker - With Amp      Blue - Red      +,-      Amplifier under passenger seat, brown 14 pin plug, pins 6 - 1
Right Rear Speaker - With Amp      Lt. Green - Violet      +,-      Amplifier under passenger seat, brown 14 pin plug, pins 7 - 8
Center Channel - With Amp      Violet - Tan      +,-      Amplifier under passenger seat, brown 23 pin plug, pins 11 - 1
Subwoofer - With Amp      Yellow - Brown (preamp); Breen (sub amp turn-on)      +,-; +      Amplifier under passenger seat, brown 14 pin plug, pins 14 - 5; brown 23 pin plug, pin 21
Factory Amp Turn-on      Brown      +      Radio, white 20 pin plug, pin 1
amriy152
Member - Posts: 6
Posted: July 01, 2018 at 10:48 AM / IP Logged Link to Post Post Reply Quote amriy152
Hello, thanks for your fast replies, does these ccolor codes apply to the oem harness of the radio?
https://ibb.co/kPZ6Ky
Posted: July 01, 2018 at 4:27 PM / IP Logged Link to Post Post Reply Quote i am an idiot
amriy152
Member - Posts: 6
Posted: August 08, 2018 at 10:04 PM / IP Logged Link to Post Post Reply Quote amriy152
Do you know a speaker L&R signal before the amplifier? The signals you gave that were after the amplifier cut off the lower frequencies of the sub when connected to an LOC. Heres a picture of the harness thats before the amplifier
2018 Nissan Rogue Head Unit Wiring -- posted image.
Posted: August 09, 2018 at 5:43 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Chances are the signal from the radio will not be enough level to drive an amplifier. Is there a factory subwoofer?
amriy152
Member - Posts: 6
Posted: August 09, 2018 at 7:33 PM / IP Logged Link to Post Post Reply Quote amriy152
Even with a LOC? yes it comes with a factory subwoofer.
Posted: August 10, 2018 at 9:36 AM / IP Logged Link to Post Post Reply Quote i am an idiot
An LOC converts speaker level to preamp level. Wires between radio and amplifier are preamp level. Very few vehicles with an OEM amplifier have enough level on their preamp section to drive an aftermarket amplifier. You will need to use an LOC but you have to connect it to the wires between the amplifier and the woofer.   How many wires are there going into the woofer?
