Viper 5305v Pin Switches and Sensors
bdgc8100
Posted: December 20, 2018 at 3:43 AM / IP Logged Link to Post Post Reply Quote bdgc8100
Need some advice on the viper 5305v installing on a truck.
It comes with 1 pin switch and id like to put that on my hood. I bought another switch for my tailgate. Can i connect both switches to the same number 9 alarm pin input?
I also have a 507m tilt switch. Ive seen 2 different ways to add that to the alarm.
So if i can get advice on the best way to install 1 pin switch on hood and 1 on tailgate. And the tilt switch.
My last alarm install was in 2000 and it had multiple sensor inputs. So just a little confused. Thanks
Greg azo
geepherder
Platinum - Posts: 3,668
Posted: December 20, 2018 at 8:20 AM / IP Logged Link to Post Post Reply Quote geepherder
While you can connect both pin switches to this wire, I suggest using the trunk (blue - instant trigger) input for the tailgate. You may need an L-bracket to install the pin in the tailgate. Alternatively, you might consider a magnetic reed switch (more low-profile).
bdgc8100
Posted: December 20, 2018 at 8:47 AM / IP Logged Link to Post Post Reply Quote bdgc8100
Thanks. Yeah thats where i was confused as it said to hookup the tilt sensor to that wire too. Thats when i figured id just hook both pin switches together. Another option was to wire the tilt switch to the green shock sensor wire harness. So just looking for whats best.
Greg azo
