If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Friday, November 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
What's my connection setup with the relay. Do I put terminals 30 and 87a between the ignition wire going to the ignition switch, use yellow/white wire for ground and tap another ignition wire for positive?
Now the only thing I wanna do before putting everything back together is somehow activate the heated seats and steering wheel.
I still have a bunch of wires on the 12 pin connector. I only used 1 for trunk. But looks like they're all negative.
I'm thinking what I can use to activate it. I don't know if it needs a constant power or just a pulse to turn it on.
I need to think of some kind of a signal that activates the switch and then disengages the power.
This is a special case compared to all the wiring I did. It needs to be activated and then it works for a while before it shuts off and needs to be activated again. Kinda like the starter
Everything is the same on my connector except mine doesnt have rear heated seats.
Once I removed the connector, I used 12 volts wall charger to supply pin 3 with power, and the light on the button came on.
So I'm thinking that when I press the button in my car, the circuit closes and the seats are heated for some time. After a while they're programmed to turn off so the power gets shut off.
I figure in this case I simply need to provide continuous power to pin 3 and it would activate the heating.
I'm not sure what pin 2 is for.
But I would've expected to have unlimited resistance between ground and power wires that went to 0 once I pressed the button.
If I can't figure it out, maybe I would connect directly to the heater connector under the seat and add an extra switch to turn it off once I'm inside the car after in warmed up.
