Door Unlock Problem, 1999 Dodge Ram 1500
rtsitler
Member - Posts: 11
Posted: February 11, 2020 at 6:33 AM / IP Logged Link to Post Post Reply Quote rtsitler
Okay vehicle is a 1999 dodge ram 1500 pickup and I have an autostart as1775 installed for remote start and keyless entry.
So the other day I tried to unlock the doors and it wouldn't work.
Key fob will remote start, unlock and end start like they should.
The door locks are working perfectly with the switches in the truck and when I hit the unlock on the remote the lights flash and you can hear the autostart unit click but it wont trigger the unlock.
I had a look at it and all the wire seemed connected still.
Any advice would be greatly appreciated .
Platinum - Posts: 13,725
Posted: February 11, 2020 at 10:01 AM / IP Logged Link to Post Post Reply Quote i am an idiot
How is the connection made? What wire of the truck do you have for unlock?
rtsitler
Member - Posts: 11
Posted: February 11, 2020 at 1:22 PM / IP Logged Link to Post Post Reply Quote rtsitler
I'm not quite sure what you are asking.
It looks like the green wire(unlock) is connected to a wire that I cant tell the color because it had tape wrapped around it and it's nearly unrecognizable due to tape residue.
Mind you this unit has been installed in this truck for better than 8 years with no problems.
Posted: February 11, 2020 at 4:16 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Is the wire of the alarm soldered to the wire? Or was it just wrapped around and covered with tape?
rtsitler
Member - Posts: 11
Posted: February 11, 2020 at 6:55 PM / IP Logged Link to Post Post Reply Quote rtsitler
Crimped with butt connector.
Posted: February 12, 2020 at 1:16 PM / IP Logged Link to Post Post Reply Quote i am an idiot
If you unplug harness from alarm and ground that wire, does that unlock the doors?
rtsitler
Member - Posts: 11
Posted: February 12, 2020 at 1:46 PM / IP Logged Link to Post Post Reply Quote rtsitler
How would I go about doing that?
geepherder
Platinum - Posts: 3,668
Posted: February 13, 2020 at 5:01 AM / IP Logged Link to Post Post Reply Quote geepherder
Follow the green wire back to the Autostart and unplug that harness. Use a piece of wire to touch that green wire to a known good ground (the outside of the cigarette lighter outlet will work).
rtsitler
Member - Posts: 11
Posted: February 13, 2020 at 5:44 AM / IP Logged Link to Post Post Reply Quote rtsitler
I'll do this later.
When I ground it, should it unlock?
rtsitler
Member - Posts: 11
Posted: February 13, 2020 at 6:29 AM / IP Logged Link to Post Post Reply Quote rtsitler
I grounded the green wire and pressed the unlock button on my remote with no change.
Brain still clicked but no unlock.
