Does The 12V Wire Need To Be Constant?
josephc04
Posted: June 15, 2020 at 7:41 PM / IP Logged Link to Post Post Reply Quote josephc04
Currently looking to install a Viper 4105 in my 2009 Ford Escape. There are two wires on the remote start harness that show they should be connected to a "(+) (30A) HIGH CURRENT 12V INPUT". Should that wire be a 12V constant, or should it only supply 12V when the ignition is in the run or on position?
Thanks in advance.
Platinum - Posts: 7,827
Posted: June 15, 2020 at 7:56 PM / IP Logged Link to Post Post Reply Quote kreg357
Must be constant. This constant power allows the system to be ON awaiting commands from the Viper 4105 remotes.
Wednesday, August 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
