2005 Dodge Ram 2500, CM900AS Remote Start
cutoutcummins
Member - Posts: 14
Posted: January 12, 2022 at 9:20 AM / IP Logged Link to Post Post Reply Quote cutoutcummins
Programming wise everything is in order. But from what I've seen/read I have to turn it on with the remote initially. The video I watched and what I've read any 4 button remote can turn it on. But when I try I get no confirmation flash. I've only found a couple remotes that show they can do it. I'd like to have a 2 way remote so I can see if the truck has started but not thrilled on having to spend $150+ on a remote
2004 Dodge ram 2500 5.7L Hemi
cutoutcummins
Member - Posts: 14
Posted: January 19, 2022 at 11:43 AM / IP Logged Link to Post Post Reply Quote cutoutcummins
I tried adding a 2WT9R-FM with the 2wFMX antenna and couldn't get the remote to program to the cm900as. Tried multiple times and nothing. I did the on/off 5 times then lock method and nothing. I'm stumped on why it wouldn't program. I was able to get the RF-2WG15-FM remote to take.
On a separate note, I picked up a firstech OP500 programmer. The first time I used it I was able to connect. I tried today and would only get an error 01. Not sure what caused it.
Platinum - Posts: 7,828
Posted: January 19, 2022 at 2:31 PM / IP Logged Link to Post Post Reply Quote kreg357
OP-500 ERR 01 = CM900-AS is Locked/Armed.
Do an Unlock first them connect the OP-500.
