box size
silverbullet00
Member - Posts: 18
Posted: June 19, 2003 at 4:31 PM / IP Logged
I am going to be building my box tomorrow. I have 4 10" Audiobahn and want to build a sealed box. I will be mounting the subs magnet inside the box. From how I figure it, this is what I need:
1.1 cubic feet/per sub
total of 4.4 cubic feet
magnet takes up approx. .3 cubic feet so I need to add on 1.2 cubic feet for a total of 5.6 cubic feet.
These are the measurements that I came up with, keep in mind I added 3/4" for wood thickness. Can one of the audio experts here verify that this all adds up and I did not mess up somewhere?
33"x26.25"x12.5"
bberman1
Gold - Posts: 2,314
Posted: June 19, 2003 at 4:48 PM / IP Logged
First off we need the model# for the subs. But if Audiobahn suggests 1 cu/ft per sub then the displacement of the sub is already taken into account. Also are you going to have separate chambers for each sub?
djfearny2
Silver - Posts: 810
Posted: June 19, 2003 at 5:00 PM / IP Logged
second of all if your making a rectengular type box that the front peice will have to be a minimum or 42 iches long cause yopu need like 10 inches pers sub. plus change.
Jon
Installer/Help Technician
---coral springs florida---
silverbullet00
Member - Posts: 18
Posted: June 19, 2003 at 5:10 PM / IP Logged
I am not sure of the model number yet.  I bought them from a buddy of mine.  There will be no chambers unless it is better to do it that way.
silverbullet00
Member - Posts: 18
Posted: June 19, 2003 at 5:12 PM / IP Logged
Where my current bos is right now, it is almost maxed out for width unless I bring it out further towards the back of the trunk.  Couldn't I put 2 in the front and 2 on the top or is that a bad idea?
Maxst
Silver - Posts: 866
Posted: June 19, 2003 at 5:45 PM / IP Logged
I'm sure you need to have seperate cambers for each sub.
I need quality equipment, feel free to donate.
silverbullet00
Member - Posts: 18
Posted: June 19, 2003 at 6:50 PM / IP Logged
My buddy has them in a box with no chambersc, in his civic.
Greenmachine
Member - Posts: 10
Posted: June 19, 2003 at 6:52 PM / IP Logged
You won't need seperate chambers unless you intend to run them wired up for a mono signal.
Silky smooth and rockin hard
Ecotec power
silverbullet00
Member - Posts: 18
Posted: June 19, 2003 at 7:19 PM / IP Logged
Here is a link for the specs for my subs.  If someone can tell me by this what I need for air space and if the magnet is included in the calculations. http://www.audiobahninc.com/tech/2001.pdf
bberman1
Gold - Posts: 2,314
Posted: June 19, 2003 at 7:55 PM / IP Logged
The displacement is included in Audiobahns volume calcs. I would suggest 1 cu/ft per sub and I would have a separate chamber for each sub. You can use the 12 volts volume calculator to aid you in designing your enclosure https://www.the12volt.com/caraudio/boxcalcs.asp#rec
