best fabric
pureRF
Silver - Posts: 619
Posted: October 14, 2003 at 9:09 PM / IP Logged
I just used my fabric and used 100% poly but it was real thin. It worked great i just had to slop on resin at the sub ring but it worked really well
dream it, build it, fiberglass it
Crush
Member - Posts: 8
Posted: October 15, 2003 at 7:51 PM / IP Logged
we have had no luck with the fleece
i cracks on us any ideas?
we used fishfabric it was a little better but it seems carpet work better.
would like to know how everyone is doing with the fiberglass cracking.
why am i the only one in the world that has that problem?
pureRF
Silver - Posts: 619
Posted: October 15, 2003 at 8:04 PM / IP Logged
if u put enough mat on and make it strong it wont crack
CarTrix
Member - Posts: 6
Posted: October 20, 2003 at 3:21 PM / IP Logged
I always start with grill cloth and then put two or three layers of glass CLOTH...not glass mat over the top of the grill cloth.... this builds a VERY sturdy enclosure that is VERY easy to finish... minimal sanding then spray it with 3m sprayable polyester filler and block it out... prime...paint...done
Good Luck
Erik
Manager/Installer
Car Tix
Ogden Utah
allchromed01r1
Member - Posts: 36
Posted: October 20, 2003 at 3:43 PM / IP Logged
Erik,
Got a quick question for ya,
Im doing my first big fiberglass job which entails glassing the whole back end of a yukon. Ive been doing fiberglass for a while just never painted as a finish till now. So im tryin to learn the easiest way to get the smooth finish for the paint. The 3m sprayable polyester filler your talkin about, does it act kind of like a filler primer, filling the small indentations and such? Any other advice would greatly be aprpreciated!
Chris
CarTrix
Member - Posts: 6
Posted: October 20, 2003 at 6:02 PM / IP Logged
k... The finish is the fun part... if you build the enclosure and panels the way i described above, you will have a relatively smooth finish to work with. Some minor sanding with 180 & 220 grit paper on a DA sander should knock down any rough or high spots.. spray on the 3m poly with a gun applying a couple of good coats (don't worry about runs... this stuff sands like a dream) let it dry and you're ready to block it out, I use brown primer as a guide to insure all low/high spots get attention and start sanding (use a flexible block with 220 grit paper)DONT USE A D/A OR BARE HANDS! as doing so will cause ripples in the finish... if you need to...do another layer of spray poly and repeat the blocking process then prime and paint...
Good Luck,
Erik
Manager/Installer
Car Trix
Ogden Utah
CarTrix
Member - Posts: 6
Posted: October 20, 2003 at 6:07 PM / IP Logged
and the spray poly does fill most imperfections, if there are any left use a glazing putty.. I prefer Evercoat Metal Glaze Blending Putty and if needs be you can finish off the primed box by wet sanding with 400 or 600 grit paper...
Erik
pureRF
Silver - Posts: 619
Posted: October 23, 2003 at 2:19 PM / IP Logged
cartrix i pretty much have my whole box done but it was done mostly with mat and some cloth, cloth will probly be the last layer. But after i sand for millions of hours and then bondo and sand more and wetsand how do u suggest i get that professional look, where it looks like a car finish? Would i get it painted at a body shop?
cmaroman95
Member - Posts: 22
Posted: October 23, 2003 at 7:08 PM / IP Logged
yeah what you would do is just take it to a body shop have them prime it and wetsand again to get all the imperfections out(cause ounce you prime it you find alot more of them) and then choose the color and have them paint it like a regular car.
"get in where you fit in"
pureRF
Silver - Posts: 619
Posted: October 24, 2003 at 1:53 PM / IP Logged
couldnt i prime it then find the imperfections because i heard it would be a ton less if they just have to do the painting and no sanding
Page of 4
