1987 GMC Suburban, Omega RS-7K2
icebolt4
Posted: July 25, 2002 at 10:09 PM / IP Logged
I have a 1987 GMC Suburban and I have a Omega RS-7K2 remote starer that I am trying to install. I need the wiring diagram for the ignition switch and I also wanted to know if I had to hook the hood switch up or is there a way to bypass that. please help me
thanks
will
icebolt4
Posted: July 25, 2002 at 10:14 PM / IP Logged
I also wanted to know where the ignition switch is located, someone told me that I had to lower my steering column.
Platinum - Posts: 12,488
Posted: July 26, 2002 at 5:32 AM / IP Logged
GMC
Suburban
1987-1994
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW OR VIOLET
IGNITION SWITCH HARNESS **
Ignition  #1:
PINK
Ignition #2:
ORANGE
IGNITION SWITCH HARNESS (HEAT-A/C) ***
Ignition  #3:
N/A
Accessory:
BROWN
IGNITION SWITCH HARNESS (RADIO/WIPER)
Brake  Light:
WHITE (+)
SWITCH ON BRAKE PEDAL BRACKET
Tach  Signal:
WHITE
AT DISTRIBUTOR OR IGNITION COIL *
Parking Lights:
BROWN
(+) AT HEADLIGHT SWITCH
Headlights:
YELLOW (+)
HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * WHITE Tach Wire Also Located In Tach Test Connector Taped To Harness Near Distributor. **  GM Rear Wheel Drive Vehicles ***  High Current Ignition Wires : Some GM vehicles are equipped with both front and rear Heater/AC blower motors. Both of these motors receive power from thesame source ignition wire in the vehicle. To accommodate the extra current drawn by the rear blower motor, connect the relay . If you do not have a rear Heater/AC, then simplywire the vehicle normally.
GMC
Suburban
1987-1994
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED AND RED
IGNITION SWITCH HARN./BOTH 1 CIRCUIT
Starter  Kill:
YELLOW OR VIOLET
Ignition  +12 Volts:
PINK
Dome  Lights/Superv:
WHITE (87-91) ORG/BLK
(92-93) (-)
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS OR AT RELAY
Power  Lock:
LIGHT BLUE
DRIVER'S KICK OR BELOW SPEAKER ****
Power  Unlock:
BLACK/ WHITE OR BLACK
Trunk  Release:
N/A
Alarm  Input Wire:
(92-93) (-)
Notes:
****  Positive Pulse Door Lock
GENERAL MOTORS REAR WHEEL DRIVE VEHICLES
All General Motors (GM) vehicles built prior to 1995 and Dodge Dakotas with a 2.5 liter engine built prior to 1996 do not have an electrical Neutral Safety switch. They have a mechanical neutral safety switch in the ignition cylinder. A mechanical neutral safety switch operates as follows:
a) The vehicle will start with the key no matter what the position of the shifter.
b) The key can only be removed from the ignition switch when the shifter is the in Park position.
On all rear wheeled passenger cars built since 1995 and all trucks built since 1996, General Motors has since corrected this potential problem by installing electronic neutral safety switches. Applying +12 volts into the Starter wire on any of these types of vehicles will engage the vehicle’s starter, regardless of the shifter’s position. With the shifter in Park or Neutral this is fine — the vehicle will just start up. If the shifter is in any other position, the vehicles will lurch forward or backward if power is applied to the starter motor — such as by a remote starter. Thus is is absolutely essential to remove the key from this vehicle when leaving the vehicle.
Sunday, June 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
