mustang trunk pin
black01gt
Posted: February 14, 2004 at 7:15 PM / IP Logged
i have looked all over under my dash and in the driver side kick panel. were can i find the wire for the trunk pin? and is ir really brown white? this is a 2001 mustang..
securinu
Silver - Posts: 772
Posted: February 14, 2004 at 9:36 PM / IP Logged
It is BROWN / white in DKP or @ gem module above DKP
Joe O'Byrne
Owner / Installer
black01gt
Posted: February 15, 2004 at 7:29 PM / IP Logged
ok i found the wire. it shows 12v when the trunk is closed? and none when it opens. problem is i hooked up the neg trigger wire, but after about 1/2 hour the alarm goes off for no reason. any suggestions?
brnichols03
Member - Posts: 21
Posted: February 20, 2004 at 12:42 AM / IP Logged
did you diode isolate it from the other triggers?
chriswallace187
Gold - Posts: 1,661
Posted: February 20, 2004 at 1:28 AM / IP Logged
On Fords like that the GEM shuts down after like 1/2 hr or so to conserve battery power, and that change in voltage can cause a false alarm trigger. To fix that the easiest way is to wire diodes inline on the trunk and door trigger wires, with the striped side facing away from the GEM and the alarm's input wires tapped on the striped side.
Tuesday, July 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
