Popping sub?
hickoutlaw2
Posted: May 07, 2004 at 6:39 PM / IP Logged
Hi, I just had a quick question that will probably sound dumb to some of you seasoned veterans. I've got 2 rockford fosgate punch HX2 12's and they are in a sealed box with 1.25 cu ft. per chamber and I am pushing them with a power acoustik amp which I'm running at 370 X 2 RMS, and each sub is 500 RMS. When I turn the volume up (not even very much) it sounds OK but I keep hearing a wierd popping sound during strong or sudden bass notes and it is really getting quite annoying. I wouldn't think that they are being over powered because it does it with nowhere near 500 watts. Please help.
forbidden
Platinum - Posts: 5,354
Posted: May 07, 2004 at 6:44 PM / IP Logged
Where is the gain on the amp set at and does the amp have a bass boost control?
sam1
Copper - Posts: 151
Posted: May 07, 2004 at 6:46 PM / IP Logged
i had that problem once when my box was too small.  but if youve got 1.25cuft, thats not the problem.  wheres your gains at?  if they are up too high it will do that as well.  actually thats where id put my money.  probably clipping your subs.  try turning it down a 1/2 of a turn or so and see what happens.
sam1
Copper - Posts: 151
Posted: May 07, 2004 at 6:47 PM / IP Logged
hey, you beet me to it.  i wanted to be first=).  j/k
hickoutlaw2
Posted: May 07, 2004 at 6:59 PM / IP Logged
The crossover is set at 80htz and the amp doesn't have a gain setting on it.
hickoutlaw2
Posted: May 07, 2004 at 7:01 PM / IP Logged
And yes the amp does have a bass boost control but when it is off, it can barely make the subs move.
forbidden
Posted: May 07, 2004 at 7:21 PM / IP Logged
Give your head a shake and go back and look at the amp, yes it will have a gain control, it may not say gain but may say something different. Post the exact model # of your subs and amp.
hickoutlaw2
Posted: May 07, 2004 at 7:51 PM / IP Logged
The subs are the fosgate RFD2112's and the amp is the power acoustik gothic series OV2-1600, and by gain would that be the "level" knob?
forbidden
Posted: May 07, 2004 at 8:38 PM / IP Logged
Yes that is the gain control, if it is turned up, turn it down. You have dual 2 ohm subs by your last post, this means that you are either running the amp at 1 ohm stereo if the subs are parallel wired(expect it to die a horrible death and take your subs with it). The other option is that you have series wired the subs to each channel. The subs will like this, the amp will like this and I like this. The amp you have will make that kind of power when it gets struck by Lightning and is going downhill with a tailwind with all the occupants rowing as fast as they can and the subs facing backwards for an extra push. You have good subs, give them a way better amp.
hickoutlaw2
Posted: May 07, 2004 at 9:08 PM / IP Logged
The gain is about 70% up. If I did look at replacing the amp what would you recommend to get? I am most likely going to get one more sub this summer, and please keep in mind i'm not rich. Thanks a lot for all your help!
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
