Front parking lights/signals won't flash
csx929
Member - Posts: 29
Posted: June 10, 2004 at 5:14 PM / IP Logged
I finally got the alarm into a 65 mustang, everything works fine except for the light flash. Only the rear lights flash. My guess is that I may have to diode isoltae each individual front signal using the turn signal wires, then connect it to the parking light flash from the alarm? The front parking lights also double as the turn signals, and I think that is what is causing the problem. Any ideas/suggestions? Thanks.
Chris
draasch
Gold - Posts: 2,172
Posted: June 11, 2004 at 6:10 AM / IP Logged
did you meter the wire???
where did you hook up to the lights???
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
deviousjoker
Copper - Posts: 102
Posted: June 11, 2004 at 2:23 PM / IP Logged
you might have 2 seperate wires coming off your switch one for the front and one for the rear.......but I don't think that's what you have since your car is older........if you didn't go to the switch for your wire then try going to the switch.......you might have just grabbed your tail light wire coming from the fuse box.
First Class MECP Installer
csx929
Member - Posts: 29
Posted: June 11, 2004 at 4:30 PM / IP Logged
The wire I used had 12volts when the parking/headlight switch was pulled, and was located coming off the fusebox. So I connected the white wire off the alarm there.
draasch
Gold - Posts: 2,172
Posted: June 11, 2004 at 5:14 PM / IP Logged
find the wire at the switch.....
Good Luck
David
Ace Security
813-376-9778
Tampa
csx929
Member - Posts: 29
Posted: June 13, 2004 at 5:49 PM / IP Logged
Well I pulled the switch assembly out, and tested every single wire, and it turns out that the front two parking/turn signals are independent of the rear lighting. So I take it the best method is to diode isolate the two wires? The only thing I'm not sure is what kind of diode to use. I've never bought them before, and at a radioshack, the only one I found that was 12volt was rated at 21 milliamps. What kind of diodes will I need for this application?
draasch
Gold - Posts: 2,172
Posted: June 13, 2004 at 6:48 PM / IP Logged
i amp diodes will do....i think its like a 1n4001 or something like that....Radio Shack should have them.....
Good Luck
David
Ace Security
813-376-9778
Tampa
draasch
Gold - Posts: 2,172
Posted: June 13, 2004 at 6:51 PM / IP Logged
that should be 1 amp diodes.....
Good Luck
David
Ace Security
813-376-9778
Tampa
csx929
Member - Posts: 29
Posted: June 13, 2004 at 7:02 PM / IP Logged
Does the voltage it's rated at matter? because there's like 50v, 200v, and 400v ratings.
draasch
Gold - Posts: 2,172
Posted: June 13, 2004 at 7:07 PM / IP Logged
1 ampere (1N4001/L)
the car is only 12v, so as close as possible will do
Good Luck
David
Ace Security
813-376-9778
Tampa
