rca input question
jussam
Copper - Posts: 78
Posted: June 14, 2004 at 5:41 PM / IP Logged
i connected  a loc to rca input very low sound ,buy when i remove one input jack woofer starts to work .can it be the amp or the loc strange
stevdart
Platinum - Posts: 5,816
Posted: June 14, 2004 at 7:06 PM / IP Logged
Two of the wires of the LOC are connected to the wrong speaker wires, and you are getting a cancelled signal when you plug both RCA's in.  There is a wire that should be connected to the positive that, instead, is connected to the negative speaker wire.  And the neg is tapped into the pos.  Reverse these two connections.
jussam
Copper - Posts: 78
Posted: June 14, 2004 at 7:35 PM / IP Logged
thanks  stevdart
did what you said bingo got thump both inputs are in
thanks again
 jussam
stevdart
Posted: June 14, 2004 at 7:57 PM / IP Logged
That was quick!  Glad to be able to help.  Just to check if sub's in phase with rest of the system, if the amp has a 180 switch, try it both ways.  If it doesn't, reverse the speaker leads from the sub to the amp to switch phase.  The proper phase is when the sub is loudest and deepest with the rest of the music.  This is just to make sure you reversed the proper wires.
jussam
Copper - Posts: 78
Posted: June 14, 2004 at 8:15 PM / IP Logged
will check out phase  tomorrow
thanks again
jussam
Copper - Posts: 78
Posted: June 15, 2004 at 5:45 PM / IP Logged
ok did the phase check everything sounds awsome.  remote to control bass set up up front,but now when connecting remote lead on . the fan on the amp whines loud  is that normal ?not through speakers ,just internal on the amp
stevdart
Posted: June 15, 2004 at 6:13 PM / IP Logged
I can't figure that one.  I'll bump this up so someone will take a look at it.
jussam
Copper - Posts: 78
Posted: June 15, 2004 at 7:26 PM / IP Logged
i'll take any suggestion with this problem i'm having.
 the internal fan on the amp  whines internally not through speakers when remote lead on is connected
Ravendarat
Platinum - Posts: 2,806
Posted: June 15, 2004 at 10:34 PM / IP Logged
What kinda amp is it
stevdart
Posted: June 15, 2004 at 11:11 PM / IP Logged
Plug bass remote into the amp, turn to max., then reset the gain on the amp.  But first turn off the bass boost.  I think the bass remote is whacking out the gain setting, and the amp is running hotter at a clipping level.  So the fan is whining.  You should already have set the gain once, so turn everything back to the starting line and do it again with that remote in.  See if that does the job.
