94 GMC Safari wiring help
tmallery02
Posted: October 22, 2004 at 11:39 PM / IP Logged
Hello,
I need assistance with reaching the ignition, starter, and other wires that are in the ignition harness. I believe that they come out right above the steering column, but I can’t just attach the alarm wires directly because there is so much other stuff in the way. I’m sure I will have to unbolt something’s, but I would like to unbolt as few things as I can.
Thanks,
Thomas
draasch
Gold - Posts: 2,172
Posted: October 23, 2004 at 11:48 AM / IP Logged
remove the lower dash and you should see a large plug and or the wires there
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
tmallery
Member - Posts: 15
Posted: October 23, 2004 at 4:15 PM / IP Logged
Okay I got lower dash off, and I see a grouping of wires coming out on the bottom of the steering colum. There is a large white plug with some wires coming out of it, but none that are the const 12v. I also see a few wires, a little heavier gauge, on coming out on the top. I think the ones on the top are what I need.
If you would like I can send you some images of what Im looking at. I can't post them because they are bigger that 30kbs.
P.S. if im testing to make sure I have the starter and igniton wire when will I get a volt reading on each of those wires.
tmallery
Member - Posts: 15
Posted: October 23, 2004 at 4:16 PM / IP Logged
If you would like I can send you some images of what Im looking at. I can't post them because they are bigger than 30kbs.
tmallery
Member - Posts: 15
Posted: October 23, 2004 at 4:17 PM / IP Logged
opps, sorry for double post
mo12v
Posted: October 23, 2004 at 6:29 PM / IP Logged
Starter = When U Turn the Key to START
Ignition  1= When U Turn the key to START
Constant 12 voltsRED OR REDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterPURPLE-AUTOMATIC TRANSYELLOW - MANUAL TRANSMISSION
Dome LightBLACK/ ORANGE(-) AT PIN SWITCH *
Trunk Pin SwitchSAME AS ABOVEALL DOORS ARE ONE CIRCUIT
Parking LampBROWN(+) AT LIGHT SWITCH
Power LockLIGHT BLUEDRIVER KICK
Power UnlockBLACK/ WHITE OR BLACKPANEL
Positive Pulse Door Lock Diagram.
* If Equipped With Auxillary Lighting Option, Dome Light Can Be Turned Off By A Switch That Interrrupts The The Door Pin Circuit To The Courtesy Lights. If Connection Is Made At This Switch, Use ORANGE / BLACK (-). Without Auxillary Lighting Option, Wire At Door Pin Switch Will Be WHITE (-).
Accessories
Window UpD\ D BLU P\ D BLU/WHT @ MAIN SWITCH
Window DownR/ BRN S/ TAN
Ign Key WarnLIGHT GREEN (-)STEERING COLUMN HARNESS OR CHIME MOD.
Trunk ReleaseRED(+) AT RELEASE SWITCH #231
OEM HornBLACK (-)STEERING COLUMN HARNESS OR AT RELAY
HeadlightsYELLOW (+)HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
 Reversal Rest At Ground Power Window Circuit
Positive Pulse Trunk Release
Remote Start
Tach SignalWHITEAT DISTRIBUTOR OR AT COIL *
Ignition #2ORANGEIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBROWNIGNITION SWITCH HARNESS (RADIO/WIPER)
Neutral SafetyORANGE / BLACK (85-87)LT BLUE (88-94) LOWER STEERING COLUMN
Brake LightWHITEAT SWITCH ON BRAKE PEDAL BRACKET
Reverse LightLIGHT GREENAT SWITCH
Rear Window Defrost
* Throttle Body Injection Engine.
MO
tmallery
Member - Posts: 15
Posted: October 23, 2004 at 6:40 PM / IP Logged
Thank you,
Let me see if I have this correctly.
The ignition key has voltage on it when the key is turned to start, and keeps the voltage until the car is turned off.
Does the accessory wire lose the voltage when the car is turned on. I found a wire that I think is the accessory wire, and it has voltage when the key is set to acc, and it when the car is on it doesn't have any voltage on it.
Does the starter wire mantain voltage when the car is on, or just when the car is starting?
mo12v
Posted: October 23, 2004 at 6:47 PM / IP Logged
Not sure what U R installing:
I posted the colors.  There R 2 Ignition wires ....  Pink #1 & Orange #2
Accessory is Brown.
Ignition will show 12 volts as the key is turned to crank and stay 12 volts as it runs
Starter will show 12 volts as the Key is turned and 0 when Key is released
Accessory will show 12 volts when key is in Run position and 0 when Key is turned to crank
MO
tmallery
Member - Posts: 15
Posted: October 23, 2004 at 8:15 PM / IP Logged
Im trying to install a black widow bw6150 alarm, keyless entry, and remote start. Right now im just trying to hook up the power, which i did, and the ignition + starter + accesory wires.
I know what color wires im looking for, but I don't know where they are located. I found the steering column harness, but don't know where the ignition harness is. Im getting about ready to pull out the instrument panel to get a better top view of the steering column.
Thanks so much for your help.
Thomas
mo12v
Posted: October 23, 2004 at 8:43 PM / IP Logged
U can get to the wires by Removing 2 phillips screws holding plastic panel under steering column.  Unplug bottom plugs on radio box on right side of steering column.  Remove 3 9/32 screws holding radio box.  Unplug top plugs & antenna from radio box.  Remove radio box......The wires R up on steering column
MO
