Fm 2009 V2.0
m11gt
Member - Posts: 12
Posted: November 02, 2004 at 9:06 AM / IP Logged
hhmm. If the feature is working even with the ignition on that means, there is something wrong with the way it was wired. by the way i can arm the car while it is running which does not seem right.
Let me give u how i wired it and see what could be wrong.
the first section of the first table is the alarm portion, the second is the remote starter
Alarm ColorAlarmWire On Car/ ColorLocaion
yellowIgnition Input (+)BLACK/ Red Ignition Switch Harness ign#1 direct
blue/orangeRemote start Output (-)500mAign#2 relay ign#2 relay 86
blackGroundthe groundthe groundDirect chassis
red+12V Battery Input #3White Ignition Switch Harness white always 12V off/On
orangeArmed Output (-)500mAstarter kill 85whereeverStarter kill Relay 85
remote ColorAlarmWire On Car/ ColorLocaion
violetStarter outputBLACK/ White Ignition Switch Harness 30/87a on the starter kill
yellowIgnition 1 OutputBLACK/ Red Ignition Switch Harness connected direct.
orangeAccessory OutputBlueIgnition Switch Harness connected direct.
brownIgnition 2 outputBLACK / YELLOW (cold start Wire) ign#2 relay 30
red+12V battery Input #1White Ignition Switch Harness white always 12V
red+12V battery Input#2White Ignition Switch Harness white always 12V
this is the wirring for my car.
1993-94 Nissan 300ZX Security Information
Constant 12V+White Ignition Switch Harness
StarterBLACK/ White Ignition Switch Harness
IgnitionBLACK/ Red Ignition Switch Harness
Ignition 2BLACK / YELLOW (cold start Wire)
AccessoryBlue Ignition Switch Harness
TachYellow/Red Test Connector
Brake SwitchRED / Black Brake Switch
Trunk ReleaseDark Green Keyless Module behind Glove Compartment some Model
Trunk Pinn/a Works with Dome Light
Parking LightsGREEN/ Red Light Switch
Head LampPink/Black L And Pink at Switch Light Switch
Hood PinORANGE / Blue (-) Anti-Theft Module behind Glove Compartment
Factory DisarmGray/Red (-) Driver's Kick Panel or Anti-Theft Module
Door TriggerRED / White (-) Anti-Theft Module behind Glove Compartment
Door LockBrown Driver's Door Harness
Door UnlockBrown Also at Lock Timer Driver's Kick Panel
Horn WireGREEN / WHITE (-) Steering Column
m11gt
Member - Posts: 12
Posted: November 02, 2004 at 2:29 PM / IP Logged
I just rechecked the wiring. looking good IGN#2 wire is not connected to the (remote starter) portion os the alarm.
