Remote start in manual transmission Q?
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: November 06, 2004 at 6:41 PM / IP Logged
Hey guys. I'm pulling out my Clifford Ace 7500 and installing a Clifford Solaris 5. Unfortunately the Solaris doesn't provide a negative output while remote started to bypass the clutch switch. I was thinking of using the third ignition wire to do this (through a relay of course) and just wanted to confirm it wasn't a bad idea. Any other ideas would be most helpful. Thanks!
Steven Kephart
Adire Audio
forbidden
Platinum - Posts: 5,352
Posted: November 06, 2004 at 7:09 PM / IP Logged
I don't see why this wouldn't work, give it a try.
Moderator - Posts: 12,488
Posted: November 07, 2004 at 8:40 AM / IP Logged
You can even use the starter wire to trigger a relay that will engage the clutch. You don't have to have a designated status output wire to do this.
Steven Kephart
Posted: November 07, 2004 at 6:40 PM / IP Logged
Ok, apparently the ignition 3 output isn't working.  When I push in the clutch, I can remote start it.  I metered the ignition 3 output, and I'm not getting any voltage from it.  The only thing I can think of is it doesn't turn on until the engine is engaged?  I didn't see a programable feature on this ignition output.
Anyway I can definitely try hooking up the starter.  However, won't that completely bypass the clutch switch in the first place?  After all then when I turn the key to start, it will trigger my clutch relay as well.  If that were true, then I could accomplish the same thing by bypassing the clutch switch and eliminating the relay all together.  If anyone has any other ideas, please let me know.  Thanks!
Steven Kephart
Adire Audio
profuse007
Gold - Posts: 2,015
Posted: November 07, 2004 at 7:00 PM / IP Logged
try blue/orange or blueblack (-) triggers.
Houston,TX
Steven Kephart
Posted: November 07, 2004 at 7:23 PM / IP Logged
Yeah, I was trying to use the blue/orange "ignition 3" output.  I found out from a quick phone call to a friend that it was a negative trigger instead of a positive trigger I would have expected from an ignition wire.  Anyway, I couldn't get it to work right, so instead I tapped into the ignition one output.  It works just fine now.  Thanks for the help.
Steven Kephart
Adire Audio
slab42
Copper - Posts: 56
Posted: November 07, 2004 at 9:28 PM / IP Logged
Steven Kephart
Adire Audio
not a good idea, I you did what I think you did, now your clutch will be bypassed EVERYTIME your ignition is on, even with the key!  keep the 86 pin connected to ign1, but now connect pin# 85 to ign3 neg output.  that will ensure that the clutch is only bypassed when the remote start is activated ;)
Steven Kephart
Posted: November 07, 2004 at 11:24 PM / IP Logged
Oops, should have thought it through better.  That just did the same thing I was trying not to do by not using the starter wire. Remote start in manual transmission Q? - Last Post -- posted image.  I eliminated the ignition 3 wire as I couldn't get it to work.  But that was just because I got the wrong side of the clutch switch.  I figured that out when even the ignition 1 wire didn't work.  I suppose I could re-wire the relay again and use that ignition 3 wire.  Thanks!
Steven Kephart
Adire Audio
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
