door locks 2002 dodge ram
patcheye1970
Member - Posts: 15
Posted: November 16, 2004 at 8:37 AM / IP Logged
i got the alarm installed fine but i can't get the doors to unlock with the alarm. it locks fine but will not unlock. i've tried all the resistor combinations for this vehicle but neither seems to work. what am i doing wrong?
forbidden
Platinum - Posts: 5,354
Posted: November 16, 2004 at 1:44 PM / IP Logged
Do the locks still work off of the factory switch? Is there a chance that the outputs of the brain are fried?
Ravendarat
Platinum - Posts: 2,806
Posted: November 16, 2004 at 2:03 PM / IP Logged
Are you using relays with the resistors? If not try putting in a pair of relays to go negative to negative and then put your resistors in on the output side
forbidden
Posted: November 16, 2004 at 4:58 PM / IP Logged
Ah, you beat me to it. I had to do this just the other day on a SRT4. Jeff confirmed my suspicions on this before I did it. The brain just did not have strong enough of a pulse to send the lock / unlock on it's way.
patcheye1970
Member - Posts: 15
Posted: November 16, 2004 at 6:38 PM / IP Logged
yes i'm using relays and the locks still work on the factory switch.
Ravendarat
Posted: November 16, 2004 at 7:42 PM / IP Logged
Dumb question but did you try just pulsing the lock or unlock relay using a ground like the kick panel or whatever. Mabye the relays and the resistors are right but the brain has fault lock and unlock outputs.
auex
Platinum - Posts: 5,041
Posted: November 16, 2004 at 7:46 PM / IP Logged
How about regular truck or diesel? What wire did you tie into for locks?
By the way, resistances are 330 and 820 ohm.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
patcheye1970
Member - Posts: 15
Posted: November 16, 2004 at 8:26 PM / IP Logged
2002 quad cab . I used 680 on the lock side becuase 820 wouldn't work. and i tried to 330 and 320 for the unlock but no response. I tapped into the white wire with the green stripe.
