1999 cadillac stereo check engine light
KustomWerkz
Member - Posts: 6
Posted: December 10, 2004 at 5:40 PM / IP Logged
I removed the Factory stereo on a 1999 Cadillac Catera  and replaced it with a Kenwood stereo and the check engine light came on.. Have anyone experienced this problem yet?  I looked at the Wire harness and it seem to have more wires then  its suppose to .. I am not sure if the factory stereo is intergrated with the computer system of the vehicle anyway.. If anyone have any advice on this please reply or give me an email  tuandang@aol.com
ps:  the customer had thrown the factory stereo away so no i cannot plug it back in to troubleshoot. if its the factory stereo or not..
KustomWerkz
Member - Posts: 6
Posted: December 10, 2004 at 5:41 PM / IP Logged
my email address above is wrong.. it is   tuandang79@aol.com
jstruckman
Copper - Posts: 465
Posted: December 10, 2004 at 7:25 PM / IP Logged
 You need to relocate the radio in that vehicle to keep the car's computer happy, but since it is in the trash, you are out of luck on that one. Better find another stock radio for it.
Jazzy
KustomWerkz
Member - Posts: 6
Posted: December 11, 2004 at 11:21 AM / IP Logged
Hey Jazzy... so you have already experienced this problem i take it?   thanks for the reply!
Tuan
Ocuriel
Copper - Posts: 141
Posted: December 16, 2004 at 6:05 PM / IP Logged
Is he having driveability issues? He might of disconnected the battery while connecting the radio. if He did, he might need to reprogram the electronic throttle control. i can post how if you need me to. I don't think the radio is intergrated with the pcm. never seen a stock radio that is.
tech460
Copper - Posts: 118
Posted: December 17, 2004 at 10:52 AM / IP Logged
This is a class 2 data vehicle, (sometimes mistakingly called RDS). Yes you will have to relocate the factory radio manually as no one makes a data retention harness for this vehicle yet.
KustomWerkz
Member - Posts: 6
Posted: December 17, 2004 at 11:15 AM / IP Logged
hey thanks guys.. i got the class 2 data retention harness i found a company that makes it..
tech460
Copper - Posts: 118
Posted: December 17, 2004 at 1:04 PM / IP Logged
Wow! Which company makes a harness with those ends on them? I have never seen one. Are you aware that harness has different ends than the standard GM's which most manufactuers have relocation harness' for?
audifive
Copper - Posts: 89
Posted: December 17, 2004 at 1:52 PM / IP Logged
im pretty sure circuit city sells them for around $60. not the relocation harness, but a "box" that mimics the factory radio circuitry
tech460
Copper - Posts: 118
Posted: December 17, 2004 at 2:00 PM / IP Logged
That would be a Metra GMRC-01 and that will not work on the Caddies because they have a different plug and use different "retention" software. The relocation they sell will also not work as it has different plugs also.
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
