kill switch with auto start
diabloscope
Member - Posts: 48
Posted: June 09, 2005 at 2:31 AM / IP Logged
you can use just about anything you want   magnetic switch behind   a plastic panel ,   momentary switch in your headliner ,   remember those seat / pressure , reed switches i have a bunch of them  . still make $$$$ off them  . put one of those in your door panel upholstery ,bump w your elbow when you start you car and your off !!     no one will ever know , even if there sitting next to you !!!      good luck !!!
diabloscope
Member - Posts: 48
Posted: June 09, 2005 at 2:43 AM / IP Logged
I know you wanted to keep separate from the alarm...  but    I've been also using  one of the channel outputs setting to latched / reset  w / Ign  on 85    ,   12V+  on 86  , key side   30  ,  starter side   87, works   great !!!!
Atl_monte
Copper - Posts: 90
Posted: June 09, 2005 at 8:28 AM / IP Logged
reed switch? never heard of that...where can I get all these special switch you guys are referring too? how does the magnetic switch work? and where would be the best place to tap into so that the auto start still works? And under the carpet is a old trick I don't think it works anymore I purchase quite a few striped cars to rebuild them and the carpet is always pulled back on the drivers side, and the power wire is still there so obvious thats not why they did it....
