2 ohm amp
acopsy88
Member - Posts: 26
Posted: August 02, 2005 at 1:13 AM / IP Logged
HI i am running a 2 ohm amp can it run at 2.67 ohms and still be stable i purchased a cheap system but thats fine with me its a 2000 watt 4 channel amp pushing 3 10 inch audiobahn  special edition dubs series
2 12 inch jl audio w3s stock infinity sound eclipse deck memphis 1000d
dwarren
Posted: August 02, 2005 at 1:20 AM / IP Logged
Sure, just don't go below 2 ohms.
acopsy88
Member - Posts: 26
Posted: August 02, 2005 at 1:25 AM / IP Logged
thanks alot  i had a problem with a 15 inch audiobahn running at 2 ohms on a pyramid amp that ran at 2 ohms and kept frying the leads ne ideas why to that?
dwarren
Posted: August 02, 2005 at 1:28 AM / IP Logged
kept frying the leads? speaker wire?
If that's what you are talking about, then there are some major issues with the amp.
acopsy88
Member - Posts: 26
Posted: August 02, 2005 at 1:30 AM / IP Logged
umm.. i mean the fuse would start sparking on the inside n it would smoke n the people the audio store said it was fried leads im only 16 im trying to learn lol
acopsy88
Member - Posts: 26
i got like installing everything im still trying to understand the ohms
dwarren
Posted: August 02, 2005 at 1:33 AM / IP Logged
Ok, well there are a few reasons as to why that could have happened, however in order to diagnose this issue more info is needed.
Specifically, what wire(s) were "fried?" I get from your last post that it could be the power cable that goes from the battery to the amp, is that correct?
acopsy88
Member - Posts: 26
Posted: August 02, 2005 at 1:36 AM / IP Logged
nuthin on the outside on the inside the wire that connects the power to the motherboard?
dwarren
Posted: August 02, 2005 at 1:38 AM / IP Logged
umm, faulty amp or a it's a pyramid runnig at two ohms.2 ohm amp -- posted image.
acopsy88
Member - Posts: 26
Posted: August 02, 2005 at 1:39 AM / IP Logged
lol yeah it seems like ur a real smart audio guy should audiobahn 10s be ported i lisen to rap but i donno how to if they need too
Sunday, March 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
