2000 mazda protege keyless entry
Methree
Member - Posts: 15
Posted: August 09, 2005 at 9:42 PM / IP Logged
ok, got the kick panel out and i found the GREEN/ red wire. but how do i wire into it to make my keyless entry work? i understand that it grounds out the 12v source to unlock it but i wasnt sure how to wire this. do i end up w/ 2 wires attached to it or do i end up w/ one wire attached to the GREEN/ red wire? i also have a BROWN / black wire that is also connected to the lock. lmk what you guys think. thanks alot for the help. btw i wasnt sure what forum to post under so i also posted under wiring diagrams. sry bout that.
-robert
Methree
Member - Posts: 15
Posted: August 09, 2005 at 9:59 PM / IP Logged
btw whenever i do it like the manual says it always unlocks the door. there is no locking at all. and the unlock button does not activate anything with the car. the lock button unlocks the locks when i hook it up like the diagram says. i have the 2 wire system, where only one wire controls both or something like that
dare_ds69
Silver - Posts: 419
Posted: August 10, 2005 at 6:15 AM / IP Logged
Power Lock lt GREEN/ red   -  module high in driver kick
Notes: This is a one wire system, must use relays. Lock requires negative trigger through a 1.5K resistor, Unlock requires a negative trigger to the same wire.
Power Unlock same wire
you need two relays and a resistence of 1.5K or use one relay like that
86 12v fused
85 (-) lock fron alarm
87 resistence 1.5K negative
87a (-) unlock from alarm
30 goes to light GREEN/ red on the car.
how own your mind, control your life.
MECP certified. always use a DMM
Methree
Member - Posts: 15
Posted: August 10, 2005 at 8:28 AM / IP Logged
where do i get the resistor from?
Methree
Member - Posts: 15
also what number/ part number is it? could i go to radio shack to get it? thanks for the help also!!
mo12v
Posted: August 10, 2005 at 8:47 AM / IP Logged
Radio Shack 1.5 Resistor 1/4 Watt....about $2.00 for 4
MO
Methree
Member - Posts: 15
Posted: August 10, 2005 at 10:11 AM / IP Logged
where do i get the relays from?i am on my way to radio shack in a bit. thanks for the info.
Methree
Member - Posts: 15
Posted: August 10, 2005 at 2:26 PM / IP Logged
ok, got a relay from best buy. hooked it all up and the unlock button works but the lock button does not... how do i hook the resistor into the line? should i check the 2nd unlock wire for amperage or something? the unlock wire may not be doing its job or something but i dont have the resistor pluged in anywhere. where should i plug it into? lmk thanks
Methree
Member - Posts: 15
Posted: August 10, 2005 at 3:10 PM / IP Logged
ok, how do i hook the 1.5k resistor to it? and when you say negative lock and unlock, i only have 2 wires that it says to connect. a green and blue one. the lock button does not make the relay click, but the unlock does.lmk what you guys think is up.l thanks again
Methree
Member - Posts: 15
Posted: August 10, 2005 at 9:34 PM / IP Logged
ok. it does not lock. do i need to use 2 relays? if so i was reading on how to do it but it says i need to connect all the outputs to the same wire. will i have 2 wires going to the GREEN/ red wire? or will i have one to the red green and one to the BROWN / black? do i need 2 relays? lmk thanks.
Tuesday, October 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
