Power requirements for this setup?
Integrity
Copper - Posts: 66
Posted: September 25, 2005 at 8:46 AM / IP Logged
I am trying to figure out what will it take to run this setup and have no impact on power requirements or drain my battery down.
I currently have 2 alpine typer subs connected to 2 alpine mrp-m350. each amp has a rockford fosgate 1 farad CPCD10-03
what i want to do is keep this setup but add the following
2 alpine SWX-1242D 1000 watts each
2 Alpine MRD-M1005 1000 watt each
4 alpine type X 6 1/2 speakers SPX-17MB 75 watt rms 300 peak
1 alpine MRV-F545 AMP 125x4 rms
what will i need like capacitors, batteries etc.. in order to have this setup but not get ripped off with extra craqp dealers like to sell at times.
DYohn
Platinum - Posts: 10,741
Posted: September 25, 2005 at 11:04 AM / IP Logged
You'll definately need a high-output alternator and maybe a second battery.  Dump the caps.
jeffchilcott
Platinum - Posts: 2,483
Posted: September 25, 2005 at 3:41 PM / IP Logged
alternator would be the best investment for you, then you could look into a kenetik battery for under the hood.   This would be the best and most efficent route to go, but not the cheapest.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Integrity
Copper - Posts: 66
Posted: September 25, 2005 at 9:36 PM / IP Logged
what if I get 3 batteries and wire them in a series? I seen some guys do this especially when like dub magazine brings there cars to Raceway park here in oldbridge
how much money are we talking for alternator batteries etc..? rough estimate
boardinbum
Silver - Posts: 358
Posted: September 26, 2005 at 1:18 AM / IP Logged
So you're putting 2 Type R's and then 2 Type X's?
Integrity
Copper - Posts: 66
Posted: September 26, 2005 at 5:09 AM / IP Logged
i have the type r's already in with 2 amps
i will be adding 2 type x and 2 mrd-1005 amps along with a nother amp for 4 swx component speakers
stevdart
Platinum - Posts: 5,816
Posted: September 26, 2005 at 10:24 PM / IP Logged
What's your reasoning for using two different subwoofers?  You must have figured out by now that "we" think.....er, KNOW.......it's a bad idea.
Blowntweeters
Silver - Posts: 650
Posted: September 27, 2005 at 11:36 AM / IP Logged
i am wondering about the 2 types of subs also. for H.O. alternater $250 plus kenetik battery 300 to 450 but worth every penny.
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Alpine Guy
Platinum - Posts: 2,478
Posted: September 27, 2005 at 12:12 PM / IP Logged
They make HO alternators for $250? wowa, are you shure its not a legacy alternator?? lol   Anyways "Integrity" definately drop the type-r's, put the type-x's in some proper ported boxs, scrap that MRV-F545 and get a mrv-f540, its less power according to the specs on the box, but much better built to run those type-x components. Also, are you running type-x components in the back of the car? You can do it, but it would be a little more realistic to just put some type-r coaxials in the back.  but if you have the cash, all the power to you.
But definately look into a good alternator, your going to need it , and heres my reccomended alt list.  www.mechman.com, www.meangreen.com, www.ohiogen.com, dominik irregi alternators.  stay far away from alterstart, and be weary of cheap alternators, they are just that, , cheap, they may put out 180 amps, , but most likely in the red line of your vehicle, the alternators listed above put out there peak at normal driving rpm's.
Integrity
Copper - Posts: 66
Posted: September 29, 2005 at 7:41 AM / IP Logged
Well the entire reason I want to add the type x subs to my existing setup is to achieve more clarity with the bass and at a louder level considering the fact that I purchased the type x subs which they sound great why not add type x subs to the setup subs are subs right? wouldnt you achieve unsurpassed sound clarity if your running 4 subs versus 2 subs? if i get a chance later on to do so I will sketch out a drawing of what i want to accomplish. below is the current setup and the proposed let me know if this is workable withought getting an alternator setupPower requirements for this setup? -- posted image. and then the proposed
