2001 Chevrolet Malibu Remote Start
bman84
Member - Posts: 8
Posted: November 01, 2005 at 10:31 PM / IP Logged
Hi, I have a 01 Malibu which I'm trying to install a Deluxe Remote Start/Keyless Entry system(23739) from DesignTech Intl.  I have everything wired and ready to go and when I try to inintalize the unit it does nothing.  I can get it to to turn on the instrument cluster and blower with the on/off switch, but it will not initalize.  I think it might have to do with the ignition 2 wire.  In the docs it says dk green but the colors i have are 2xorg,2xpink,1ltgrn,1red,1brown,1yel.  I tried the brown wire but I think it is an accessory wire.  Is the green wire correct, could it be my reciever.  Each wire was probed and the brown and green act the same.  I read on their site that sometimes hood pin doesn't ground, but I don't want to try anything until I know my colors are correct.  I have installed designtech before with the same bypass module and had no problems.  Thanks.
05gt
Silver - Posts: 628
Posted: November 01, 2005 at 10:35 PM / IP Logged
your car needs a bypass module to bypass the factory immobilizer
You could use a DEI product, the part number is 556L
that is what I got for your car
Ignition pink   +  ignition harness   2001 Chevrolet Malibu Remote Start -- posted image.
Second Ignition dk. green   +  ignition harness   2001 Chevrolet Malibu Remote Start -- posted image.
Third Ignition
Accessory orange   +  ignition harness   2001 Chevrolet Malibu Remote Start -- posted image.
Second Accessory brown   +  ignition harness   2001 Chevrolet Malibu Remote Start -- posted image.
05gt
Silver - Posts: 628
Posted: November 01, 2005 at 10:36 PM / IP Logged
you need a byapss moduel to bypass the factory immobilizer
you can use this (556L from DEI)
this is what I got for your car
Third Ignition
Chris Luongo
Platinum - Posts: 3,746
Posted: November 01, 2005 at 10:42 PM / IP Logged
Where are you getting the ignition wires in the car?
You will find a large bundle under the driver's dash, which has most of the wires, but the dark green ignition 2 is not there.
The only way I know to get ignition 2 is to just get all of your ignition wires behind the keywitch, accessed by removing the radio. Don't unplug the radio unless you have the Theftlock code for it.
05gt
Silver - Posts: 628
Posted: November 01, 2005 at 10:43 PM / IP Logged
i was just going to say that about removing the stereo to get at all the ignition wires, but you beat me to it2001 Chevrolet Malibu Remote Start -- posted image.
bman84
Member - Posts: 8
sorry I left a line out of my post, I have the Universal Bypass Module for passlock installed and operational which has no problems.
05gt
Silver - Posts: 628
Posted: November 01, 2005 at 10:44 PM / IP Logged
alright well that answered that
bman84
Member - Posts: 8
Posted: November 01, 2005 at 10:45 PM / IP Logged
I found the wires behind the radio in the harness set with passlock wires, i'm a little confused cause there is a light green but no drk green like in my alero
05gt
Silver - Posts: 628
Posted: November 01, 2005 at 10:47 PM / IP Logged
it should be there, like how light is it, do a little testing
bman84
Member - Posts: 8
Posted: November 01, 2005 at 10:49 PM / IP Logged
its lime green, the other post said its on the ignition cylinder, is that the only place to find the drk green?
Saturday, January 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
