DEI 508D wires
jpnuebel
Member - Posts: 17
Posted: November 15, 2005 at 9:24 PM / IP Logged
I'm adding a 508 sensor to a viper 791 and I'm curious why the wire harness has plugs on both ends? I realize you need to cut and tap into the mulitplex input but was wondering why DEI has a plug.
THANX
jpn
cntrylvr79
Silver - Posts: 582
Posted: November 15, 2005 at 9:39 PM / IP Logged
Because some of their systems have a built in shock sensor and a plug for extra sensors.  Were you to be using one of those systems you'd be able to just plug the motion sensor in.
Cause I'm So white and nerdy...
First Class Certi-fried installer
Hornshockey
Silver - Posts: 520
some of their security models have shock sensors built into the brain and have a multiplex port that you can plug into that provides power ground and the trigger input.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
