2002 Acura RSX Alarm/Remote Start Wiring
audio Xclusive
Member - Posts: 30
Posted: May 12, 2002 at 9:48 AM / IP Logged
I have an rsx base model and would like to put in an alarm with remote start.
could you add the rsx to the database and provide diagrams or info on how to install remote start
in a manual transmission car
another Xclusive installation
Moderator - Posts: 12,488
Posted: May 12, 2002 at 10:25 AM / IP Logged
Acura
RSX
2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS *
Ignition  #1:
BLACK / YELLOW
Ignition #2:
BLACK/ RED
Ignition  #3:
N/A
Accessory:
WHITE/ RED
Brake  Light:
WHITE/ BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLUE
AT TEST CONNECTOR BEHIND DRIVER'S HEADLIGHT
Parking Lights:
RED / BLACK (+)
AT FUSE BOX
Headlights:
BLUE/RED (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
WHITE (-)
AT SECURITY MODULE ***
OEM Alarm  Arm:
WHITE/ RED (-)
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
Notes:
 * This Vehice Is Equipped With A Transponder Type Theft Systems.
Acura
RSX
2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
GREEN AND LT. GREEN/ RED (-)
OEM Horn:
ORANGE (-)
STEERING COLUMN HARNESS ***
Power  Lock:
WHITE/ BLUE (-)
DRIVER'S OR PASSENGER KICK PANEL ****
Power  Unlock:
WHITE/ GREEN (-)
Trunk  Release:
N/A
Alarm  Input Wire:
Notes:
** Securtiy Module Is Located To The Left Of The Steering Column. Green Is Driver's Door And Lt. GREEN/ Red Is Passenger Door. Use Both Wires For Alarm Input and Diode Isolate Both. Use Only One Wire For Dome Light Supervision. *** Security Module Is Located To The Left Of The Steering Column. **** Wires Can Also Be Found In A 13 Pin Plug At The Multiplex Control Unit Located At The Back Of The Fuse Box.
audio Xclusive
Member - Posts: 30
Posted: May 13, 2002 at 12:37 AM / IP Logged
thank you very much for the info
will I need the clutch bypass wire for remote start
if so I didn't see the color or location on the info you sent
it is a manual trans vehicle
Posted: May 13, 2002 at 5:32 AM / IP Logged
Unfortunately, I don't have this information yet as we update this info as the vehicles come in. Most Honda and Acuras have a 2 wire clutch bypass system that you can get to by reaching uder the dash. It will be a negative trigger though. Sorry, I can't help you further on this. Try to repost for the clutch bypass wire for additional help.
Big Dog
Gold - Posts: 1,265
Posted: May 13, 2002 at 7:54 AM / IP Logged
Hey Audio Xclusive,
In Acura usually the clutch bypass is easy enough.  Follow the BLACK/ White starter wire from the column to the clutch relay.  There is a thick BLACK/ Red wire which is the starter wire going out to the starter itself.  Simply put your Starter output wire of your remote starter wire here.  The E-brake wire can be found at the daytime running lights module if your car is so equipped and it is a GREEN/ Red wire neg trigg.
Prepare your future. It wasn't the lack of stones that killed the stone age.
jonj0n1
Member - Posts: 16
Posted: July 29, 2002 at 9:36 PM / IP Logged
hey is the diagram for the base model similar to  the rsx type s model?
jonj0n1
Posted: July 30, 2002 at 12:47 AM / IP Logged
They will be the same. The Type-S just has engine, exhaust & suspension differences, not the electrical or the ignition.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
