remote start on aladdin 2000
94civicex
Member - Posts: 44
Posted: January 01, 2003 at 4:30 PM / IP Logged
yo velocity i'm pretty sure i have the wire that way. it seems as if the starter wire gives no pulse when you activate the remote starter. the lights on the dash and everything comes on but no start. how can i check if the starter wire is giving a pulse or something. i was thinking of checking the starter wire that comes from the alarm with a multimeter and see if anything is going through. also what is the default time delay between ignition and start on the programming.
94civicex
Member - Posts: 44
Posted: January 01, 2003 at 4:33 PM / IP Logged
i also got another idea that just came up. the car previously had an alarm, but was tooken out when i got it. it was a basic alarm i think. do you think that a starter interrupt relay is still hooked up or something and its not allowing the car to start.
Platinum - Posts: 12,488
Posted: January 02, 2003 at 8:10 AM / IP Logged
Make sure that you have the STARTER wire on the Aladdin on the motor side of any disable circuit that you have on this car wether it is one that you added or one that was already there when you bought the car. The default time for the starter on the Aladdin is 2 seconds.
94civicex
Member - Posts: 44
Posted: January 03, 2003 at 3:14 PM / IP Logged
hold on velocity if the yellow wire is supposed to be the heater/ a/c wire why do you have it as a accesory for the pink wire on the p10 harness. the yellow doen't give any power when the ign is turned to accessory. the wht/blk wire is the accesory wire on the ignition on my car not the yellow.
94civicex
Member - Posts: 44
Posted: January 03, 2003 at 4:17 PM / IP Logged
the yellow on comes on when switched to ign.
Posted: January 03, 2003 at 11:31 PM / IP Logged
If you read the add-on slip of paper in the installation manual you will have read that the PINKp10 wire has to be attached to the BLUE P6 wire on the CPU which is your HVAC wire.... YELLOW.
Page of 3
