Rear Deck 64 impala
impaladad
Member - Posts: 14
Posted: February 26, 2006 at 10:09 PM / IP Logged
Hey ya'll. I am a newb at this forum stuff, so please excuse any errors on my part. I have a 1964 impala 2-door,  and I intend to cut the rear deck, and build a box for 2-10w3v2's ported, basically instaling them in place of the rear deck. My question is have any of you heard this design before. I know I will lose the typical DB gain by having the subs mounted firing directly into the car but I hope to offset it by using a ported design. just a little worried about permantly modifying my car, for lack-luster bass.
willdkartunes
Copper - Posts: 250
Posted: February 27, 2006 at 12:22 AM / IP Logged
The general rule that I usually go by is if your gut feeling initially tells you not to modify, then you probably shouldn't. There is nothing wrong at all with a complete factory look, but still get the bass you want. Me personally, I would leave it the way it is and add the bass in the trunk keeping the modifications as minimal as possible. That car is a classic man!Rear Deck 64 impala -- posted image.
jvillefinest
Copper - Posts: 255
Posted: February 28, 2006 at 12:45 PM / IP Logged
I have seen something similar to this before but i believe it was in an old cutlass. it was either 2 or 3 w7s. But i believe it was sealed. You might be able to find pictures of the one i saw it belonged to the owner of Davin Wheels on either the Davin Wheels Site or Car Audio and Electronics site. the install was amazing.
2007 Acura TSX
SQ setup in the works
crzy4507
Member - Posts: 12
Posted: February 28, 2006 at 7:11 PM / IP Logged
In my opinion, you should just put a ported box in the trunk and have it firing up through the rear deck.... or, i have seen cars with holes cut in the rear deck, just for the speakers and a port... still using the same deck... you just have to make sure your trunk and deck are airtight and rattle free
impaladad
Member - Posts: 14
Posted: March 01, 2006 at 12:19 PM / IP Logged
Thanks for your thoughts, guys.  I definatly have to give this some more thought!  Just trying to avoid trunk rattle, and the ugly look of sound deadeners.
