Rattler model 300 in mercedes?
advancedautotek
Member - Posts: 6
Posted: March 23, 2006 at 2:38 PM / IP Logged
Any one here that can help me? I am installing a rattler alarm model into a 85 Mercedes Benz 190e and cant seem to figure out how to connect my triggers to the vacuum lock actuators, any information diagrams etc. would be very helpful Thanks in advance.
michaelleeadvanced@hotmail.com
xscash
Copper - Posts: 317
Posted: March 23, 2006 at 2:57 PM / IP Logged
here is what i have
    XS
Doorlocks/Windows
WIRECOLORPOLARITYLOCATION
Power Unlock GREEN OR BLUE (VAC) VACUUM DOOR LOCK SYSTEM "SEE TECH TIPS"
  REQUIRES THREE SECOND LOCK PULSE
PowerLock GREEN OR BLUE (VAC) DRIVER'S KICK OR PUMP UNDER REAR SEAT
LF Window Up RF:BLACK
RF Window Up LF:BLACK/ WHITE LR:BLACK/ PINK RR:BLUE/EHT
LR Window Up RF:GREEN
RR Window Up LF:GREEN/ YELLOW LR:GREEN/ BLACK RR:GREEN/ RED
advancedautotek
Member - Posts: 6
Posted: March 23, 2006 at 2:59 PM / IP Logged
To be more specific I am attempting to get the alarm connected to the auto door locks, It is a 3 wire door lock actuator, 1 brown(-) 1 red(+)
1 green switches (-)/(+) depending on if door lock button is up or down, If I run the - trigger wire from alarm to the green or the + trigger wire to it, it will blow a fuse as the wire is still switched at the actuator itself, is there a separate unit I have to buy to get keyless entry working? Or do you know if there is a way to run relays in some sort of series to allow the alarm to operate auto door locks? This is my first run into mercedes benz vacuum locks.
Thanks in advance, Mike
xscash
Copper - Posts: 317
Posted: March 23, 2006 at 3:01 PM / IP Logged
advancedautotek
Member - Posts: 6
Posted: March 23, 2006 at 3:09 PM / IP Logged
Thx a million!!
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
