factory look
josh1979
Silver - Posts: 320
Posted: July 08, 2006 at 9:20 PM / IP Logged
heres an install i just fnished and would like to share my customers only request was take as little space as possable so with customer suplied equptment in hand this is what i came up with there are a few picks in between steps i did not take i was not planig on posting this.
first i cut a place for the woffer and laied down some dynamatt
factory look -- posted image.
i than built a small farme in where i cut out and laid down a few layers of glass this pick is missing sry dont know how i did not take one of this
next i mad a amp mounting board and a top for my enclosure
sence the brake light are on the gate i need to make a removeable cover so he could change bulbs if needed i than made a MDF gig of the factory cove panel which i inserted factory like push pins in  that lined up with the orignal holes to hold it in place than with woffer and amp in place made a frame around my equptment
i than stretched grill cloth around the frame placed it back on the truck and laid some resin. in the next pic you see it with a few layer of glass on
when all was dry i covered it in factory match carpet and bam we got bass wit less than 6 inches lost
sry for missin fotos of steps
oscarnl86
Copper - Posts: 84
Posted: July 31, 2006 at 10:59 AM / IP Logged
good job man looks goodfactory look -- posted image.
blufab
Copper - Posts: 62
Posted: July 31, 2006 at 4:21 PM / IP Logged
Stealth install that is sweet.
austincustoms
Copper - Posts: 232
Posted: July 31, 2006 at 4:29 PM / IP Logged
that looks great.  Very clean. How exactly is that held in?  Did you get all the wiring through the factory molex?
cutlass013
Copper - Posts: 95
Posted: July 31, 2006 at 7:07 PM / IP Logged
very very nice job i like the hidden look to it
josh1979
Silver - Posts: 320
Posted: July 31, 2006 at 7:18 PM / IP Logged
the amp is screwed to a 3/4 mdf plate which is bolted to the gate. the box is molded to the outer skin of the gate in a maner that will not come loose.its a 5 ch amp the power is run through the driver and the speaker/RCA's are on the left
i driled out holes and counter sunk  in  push snaps like you find on any factory door panelthan filed the holes weth resin to hold the pins in place
bring back the rotary phone so i dont have to press 1 to proceed in english
blackers10
Posted: August 01, 2006 at 1:04 PM / IP Logged
the 1 thing i dont get is how he is supposed to load up the back via the tailgate..
with the tail gate open he would wipe out the sub and amp if trying to slide somthing over them??
just a thought thats all
as he would of wanted as little space taken up due to wanting to fill the available space with?? junk i suppose?
but it does look great!
sawhit4
Copper - Posts: 64
Posted: August 01, 2006 at 6:35 PM / IP Logged
he probably only uses the back for smaller loads, like groceries.
josh1979
Silver - Posts: 320
Posted: August 01, 2006 at 6:55 PM / IP Logged
that was his only request he did not want a huge box back there
memphis9
Copper - Posts: 53
Posted: August 02, 2006 at 7:53 PM / IP Logged
Very clean install. That dose look like it comes from the factory. Nice job.
G-Boys Customz
Northville, MI
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
