2002 Chevy Tahoe Keyless
Red97LT1
Copper - Posts: 57
Posted: August 02, 2006 at 12:53 PM / IP Logged
Yes. That's what I was thinking about the keyless. How would I know if it had keyless,but he just didn't get the remotes?
sparkie
Platinum - Posts: 2,061
Posted: August 02, 2006 at 2:33 PM / IP Logged
Check the glove box for the option code sticker.   The code for keyless entry is AU0. The cost of two factory remotes and labor to program them can be very expensive. It will likely be cheaper to replace with an aftermarket unit anyways.
sparky
Red97LT1
Copper - Posts: 57
Posted: August 02, 2006 at 3:21 PM / IP Logged
Thanks.
Red97LT1
Copper - Posts: 57
Posted: August 15, 2006 at 3:47 PM / IP Logged
I have been out of town on business and am just know ordering the keyless for him. I assume that I am splicing(not cutting)into the lock/unlock wires before they go into the BCM,therefore sending a signal to the BCM by use of the remote? I don't want to do something wrong and burn something up!
Chris Luongo
Platinum - Posts: 3,746
Posted: August 15, 2006 at 5:51 PM / IP Logged
Right.
You'll obviously need the tools and ability to take down the driver's dash.........it's easy. Two 7mm bolts and the lower dash pulls off. Behind there is a metal bolster, held by four 10mm nuts; you could perhaps work around it, but removing it is recommended.
You'll also need a multimeter or test light, and the ability to use it correctly.
Finding the correct wires goes like this:
--Touch your tester onto the pin at the BCM for the wire which you think is correct.........operate the desired function (locks, lights, or whatever)......and verify that the wire is the correct one.
--Cut the tape off the wire harness, and make enough slack so you can work. Use a wire stripper to open up the insulation, but NOT cut the wire. (You might cut it by accident, but no big deal---you'll just have to reconnect it with solder, or a butt connector.)
--Once the wire's insulation is opened up a bit, poke THROUGH the copper strands with your test probe, making an opening through the middle. Put your new wire THROUGH the hole, and then wrap it tightly around the factory wire. Adding solder is never a bad idea.
--Next, wrap tape around the connection in the SAME direction you wrapped the wire.....if you try to wrap in the opposite direction, the aftermarket wire will unravel a little bit.
--Finally, when you're finished with all your connections, throw a couple of zip ties around the whole bundle......the original wire you spliced into, the OTHER original wires, and the aftermarket wire.....so they'll lock together and won't come apart if pulled on.
NOTE: That Tahoe uses positive-trigger lock and unlock wires.
Some keyless units offer outputs that flip-flop from negative to positive, which is nice and makes it easy.
Other units give ONLY a negative output, and you'll need to use a couple of relays to invert that to a positive........not a big deal, but kind of a pain.
Red97LT1
Copper - Posts: 57
Posted: August 15, 2006 at 7:11 PM / IP Logged
Chris Luongo wrote:
Right.
Thank you for the input.When you say use a tester to probe the wire,do I use the pos to the wire and the blk to a grnd to see if I get current?
Red97LT1
Copper - Posts: 57
Posted: August 15, 2006 at 7:13 PM / IP Logged
The wiring diagram I have has the wires being this...
POWER LOCK LIGHT BLUE (TYPE A)   @ BCM, BROWN PLug, Pin A4,
POWER UNLOCK WHITE (TYPE A)   @ BCM, BROWN Plug, Pin A3, 3
josh1979
Silver - Posts: 320
Posted: August 15, 2006 at 7:23 PM / IP Logged
here is all the wiring you will need and dont use any kind of test light only DMM as there is the potential to cause damage to the bcm.   If a DMM has a very high impedance or resistance it will cause a slight increase in the circuit's current. This becomes a concern when you test electronic systems because the increased current draw can damage the components being tested or, at the very least, alter the readings or change a sensor signal. You want to get a meter that has an impedance of at least 10 megaohms. That is to say their current draw is so low it becomes invisible.
Before you use your DMM to perform a test, you need to know what you are testing and what kind of results you are looking for. If you are looking for volts, you will need to select the proper range for the test. If you are looking for a 12-volt result, select a meter range higher than 12 volts. For example, a 0 to 25 volt range would be best. A range of 0 to 500 volts will not yield an accurate result.
Almost all DMMs have an "auto-range" features that will automatically select the proper range. Some DMMs will let you override this feature and let you manually select the range you want. Some DMMs do not have this option and must be set manually. Check the documentation that came with your DMM and make sure you know and understand the different ranges it is capable of.
yes you ground the com side of the DMM and probe with the other
CHEVROLET / TAHOE / 2002 / Remote Start
[PRINT THIS PAGE]
12volts red  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition white  +  ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
Keysense lt. green  -  ignition harness
Power Lock lt. blue  +  pin A4, brown plug at BCM
Notes: The BCM (Body Control Module) is located behind the driver side of the dash. The plugs face towards the rear of the vehicle.
Power Unlock white  +  pin A3, brown plug at BCM
Lock Motor gray  5wi driver kick, door harness
Unlock Motor tan  5wi driver kick, door harness
Parking Lights+ brown  +  pin B6, lt. blue plug at BCM
Parking Lights- white  -  pin A5, lt. blue plug at BCM
Hazards same as turn signals
Turn Signal(L) lt. blue  +  steering column
Turn Signal(R) dk. blue  +  steering column
Reverse Light lt. green  +  inside rear view mirror
Door Trigger   -  BCM
Use tan for the driver door located in pin B4 of the purple plug, and the passenger doors are a blue/white in pin B11 of the lt. blue plug. Use both wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin pink/black  -  pin B10, lt. blue plug at BCM
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock
Factory Alarm Disarm lt. green  -  pin B3, purple plug at BCM
Disarm No Unlock see factory alarm disarm
Tachometer white  ac  ECM
Notes: The ECM (Engine Control Module) is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is in pin 20 in the connector labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located in pin 10 in the red connector.
Wait to start dk. blue  -  instrument cluster
Brake Wire white  +  brake pedal switch
Parking Brake GREEN / WHITE  -  parking brake switch
Horn Trigger black  -  pin A9, brown plug at BCM
Memory Seat 1 white  +  memory mod under dr seat
Memory Seat 2 purple  +  memory mod under dr seat
Memory Seat 3 N/A  +
2002 Chevy Tahoe Keyless - Page 2 -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
Door Lock Interface
Required:
No
Type:
N/A
Part #: N/A
Notes:
Combo Interface
Required:
Yes
Type:
Data Bus
Part #: 457GW
Notes: Can use the 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Smart Starter Kill Relays: Not Available
bring back the rotary phone so i dont have to press 1 to proceed in english
Red97LT1
Copper - Posts: 57
Posted: August 15, 2006 at 7:35 PM / IP Logged
Am I correct in the way I mentioned about finding the correct wire? I also guess that I just need to tap into the parking lights to get them to flash during lock/unlock?
The keyless has both pos/neg options for the locks and lights,so that's not a problem.
josh1979
Silver - Posts: 320
Posted: August 15, 2006 at 8:15 PM / IP Logged
question #1 yes
question #2 yes
Page of 4
