home amp on car audio
coop513850
Posted: September 03, 2006 at 9:08 PM / IP Logged
can you use a home amp on car audio? why or why not and whats the reasoning for it?
thanks
kfr01
Gold - Posts: 2,121
Posted: September 03, 2006 at 9:17 PM / IP Logged
Yes. Why would you want to?
New Project: 2003 Pathfinder
coop513850
Posted: September 03, 2006 at 9:22 PM / IP Logged
is there any draw back from it? and if it works why would you not want to?
kfr01
Gold - Posts: 2,121
Posted: September 03, 2006 at 9:28 PM / IP Logged
Sure. No drawback. Home amps are usually only 8-ohm stable, unless you have a semi-expensive amp.
What do you own and what are you trying to do?
coop513850
Posted: September 03, 2006 at 9:32 PM / IP Logged
i have nothing but a friend has an 8 ohm home amp and 2- 4 ohm svc subs, just wondering if there are any drawbacks. i told him he is stupid and just get a proper amp. now i am just trying to get some facts.
kfr01
Gold - Posts: 2,121
Posted: September 03, 2006 at 10:09 PM / IP Logged
He should just get a proper car audio amplifier.
(1) No DC-AC converter is 100% efficient. Plus, he will spend money on this device.
(2) home audio amplifiers aren't made for the temperature or vibration abuses of the car.
Seriously, tell him to buy a car audio amplifier.
austincustoms
Copper - Posts: 232
Posted: September 04, 2006 at 12:37 AM / IP Logged
Not to mention home amps are often tube amps, and a lot more fragile, as they are designed to sit in one place, not to be tossed around in a car.  But if he doesn't mind ruining his stuff, go for it.
DYohn
Platinum - Posts: 10,741
Posted: September 04, 2006 at 9:12 AM / IP Logged
Are you talking about trying to put a "home amp" into your car (don't) or trying to use car speakers inside with a home amp (no problem)?
coop513850
Posted: September 04, 2006 at 2:26 PM / IP Logged
yeah home amp in a car. thanks for your help everyone.
DYohn
Posted: September 04, 2006 at 2:51 PM / IP Logged
That is a bad idea for many of the reasons already mentioned, but mostly because it requires 120volts.
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
