A Bank of 6 SPDT Relays?
master5
Silver - Posts: 1,123
Posted: November 05, 2006 at 10:07 PM / IP Logged
There ya go...
dscwmitchell
Posted: December 19, 2006 at 8:47 AM / IP Logged
Why not put them in a waterproof enclosure?  Then you could put whatever relay you wanted in there.  Grommets are cheap.  A small enclosure wouldn't be hard to get either.
You probably have this all figured out by now, just thought I'd give my input.
Cliff
hotwaterwizard
Silver - Posts: 1,350
Posted: December 19, 2006 at 9:46 AM / IP Logged
You could go with Industrial Din Mounted relays
A Bank of 6 SPDT Relays? - Page 2 - Last Post -- posted image.
or Sockets that snap together.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
ill-logix
Member - Posts: 39
Posted: December 19, 2006 at 2:59 PM / IP Logged
The problem with the industrial stuff is most of it is designed for 24vDC or 24/120/240vAC...  I talked to some WAGO sales guys just last week (I am an industrail controls engineer) and they had some nice stuff but not much if any 12vDC.
If you want to use a din rail I would suggest an Omron Base (P2RF-05-E) and 12vdc coild spdt relay (G2R-1-SNDI-DC12(S) ) which is about $15 bucks a pop directly from omron.  They are about 0.5 inch thin and 2.5 inches wide.  They have an ledi ndicator and a push to test button.
