2000 dodge intrepid, alarm/remote start
dbell34
Member - Posts: 47
Posted: October 30, 2006 at 8:25 AM / IP Logged
where is the best place to mount a shock sensor in a 2000 dodge intrepid?
bellsracer
Silver - Posts: 703
I find the firewall up and out of the way of things is the best place for most vehicles.
KarTuneMan
Platinum - Posts: 7,056
Posted: October 30, 2006 at 8:26 AM / IP Logged
Depends on who's installation manual your reading. On a FAT factory harness, zip tied securely. Or to some of the metal under the dash.double back taped.
For sure you need ot to be easily accessed for adjustment.
dbell34
Member - Posts: 47
Posted: October 30, 2006 at 5:34 PM / IP Logged
the idea of building a relay and hooking it up to the second ignition did not work for me if you guys have any other ideas please let me know.
KarTuneMan
Posted: October 30, 2006 at 6:03 PM / IP Logged
Why did it not work?
green6767
Copper - Posts: 209
Posted: October 30, 2006 at 6:18 PM / IP Logged
There is no reason that that relay should not have worked if you wired it properly. What is the color of the wire of the 2nd ignition in the car that you used? Make sure you have your relay wired up properly. How do you know it did not work? What color is the key for your car?
Shaun, we are the same height, that is neat!
12V Installation Technician for Honda, Dodge, Chrysler, Toyota and Jeep.
dbell34
Member - Posts: 47
Posted: October 30, 2006 at 7:01 PM / IP Logged
the second ignition wire is GREEN/ red my key is black, and the reason that i know it did not work is because the car did not start.
dbell34
Member - Posts: 47
Posted: October 31, 2006 at 1:43 PM / IP Logged
this is a diagram of the alarm, maybe someone can tell me what wire i may be able to use for the second ignition.
2000 dodge intrepid, alarm/remote start - Page 2 -- posted image.
toebeshair
Member - Posts: 12
Posted: November 01, 2006 at 8:56 PM / IP Logged
Just about to try and install the same alarm. IN A 2002 sebring conv.lxi
x-shield---xs0800s----and bypass chrdaa - v 8.0
I also have a 2nd ign. wire  which i believe we must use a relay to give it  power.????(while its remote started)??
I Dont think this unit(xs- 800s) has A  2nd ign. wire output.??
and wheres a good spot for a microware sen. in a convertible ??
Man i think we need help!! hope were not the only ones !!!
Mike M2
Platinum - Posts: 2,652
Posted: November 01, 2006 at 9:16 PM / IP Logged
Both cars here are not that hard to do. We've tried to help Dbell but he's not telling us what we need to know. There's absolutely no reason the the relay i described earlier shouldn't work. If it isn't then the only logical solution is to use a DMM and check out why. Does the relay activate when the RS comes on? Does the relay give 12volts to the second ignition wire when the RS comes on? Without knowing these things there's absolutely no way we can help. If he's not capable of checking these things then he needs to find someone that can.
As for the Sebring, have one myself, same year. Yes, it has two ignitions, and two accessories but the second doesn't need to be activated for RS operation. You will need a bypass for the immobilizer. You don't have to bypass the factory alarm, but if you don't the horn will beep once everytime you remote start when the alarm is on. To make the alarm disarm before hand, you will need a relay and a 750 ohm resistor. To connect the keyless, you will need a set of relays and two resistors, 1800 and 750 ohms.
Mike M2
Tech Manager
CS Dealer Services
Page of 3
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
