8 gauge wire on rockford 200s
nickcervantes
Member - Posts: 20
Posted: January 25, 2003 at 9:03 PM / IP Logged
can I get away with running 8 gauge wire instead of 10 gauge for power to the rockford 200s.  It's rated for 10 gauge but i already have 8 gauge wire ran im my car.  It has a 20 amp fuse on the amp.
bberman1
Gold - Posts: 2,314
Posted: January 25, 2003 at 11:18 PM / IP Logged
The smaller the gauge the bigger the cable. So A 8 gauge wire is larger than 10 guage. You can use the 12volts wire gauge calculator to figure out what size cable you will need https://www.the12volt.com/info/recwirsz.asp
ViperATC5
Copper - Posts: 202
Posted: January 25, 2003 at 11:20 PM / IP Logged
8 gauge will be fine
