legacy la 2088 2400 watt amplifier
s_goodie
Member - Posts: 44
Posted: December 02, 2007 at 2:23 PM / IP Logged
i have recently purchased a lagacy la-2088 2400 watt amplifier and when i hook it up its really weird like it powers the subwoofer but it makes weird noises and when i turn the blinker on it bumps with the sound of the blinker does anyone know wahtwrong with it
Stuey BABE
aznboi3644
Gold - Posts: 2,600
Posted: December 02, 2007 at 2:46 PM / IP Logged
VERY poor quailty amp.
How is your amp grounded???
s_goodie
Member - Posts: 44
Posted: December 02, 2007 at 2:48 PM / IP Logged
it is groudned great beacuse i hooked up a differnt amp and it dosnt do it so idk i just wish there is a way that i would maybe do something with it to fix it cause i have no money and its my only amp
Stuey BABE
Alpine Guy
Platinum - Posts: 2,478
Posted: December 02, 2007 at 2:50 PM / IP Logged
They use very very low quality components that pick up RF noise easily, just as said above, make sure you grounds are perfect.
Also, id like to add, those amps are MAJORLY over rated, you'll be luck to get 240 watts rms out of it, yet alone 2400 lol.
s_goodie
Member - Posts: 44
Posted: December 02, 2007 at 2:53 PM / IP Logged
yeah idk andi have another wuestion kinda off subject how do i change from being a rookie?.. and could it have to do with the rca's?
Stuey BABE
stevdart
Platinum - Posts: 5,816
Posted: December 02, 2007 at 3:17 PM / IP Logged
Yes, better RCAs will often change your status from rookie.
But then again, using Lagacy and wuestions like your are, it may not work.
s_goodie
Member - Posts: 44
Posted: December 02, 2007 at 6:18 PM / IP Logged
it is bolted to the bottom of the car
Stuey BABE
Platinum - Posts: 13,726
Posted: December 02, 2007 at 7:37 PM / IP Logged
Goody you are correct in assuming the problem is with the RCA.  You have a burnt trace on the circuit board of your amplifiier.  If you can tell me which speaker wires are the bridge wires I can get your amp working for you.  Is bridge Left positive and Right negative?  Or are they Left negative and Right positive?
s_goodie
Member - Posts: 44
Posted: December 02, 2007 at 9:22 PM / IP Logged
left is positive and right is negative
Stuey BABE
haemphyst
Platinum - Posts: 5,059
Posted: December 03, 2007 at 1:06 AM / IP Logged
I get 216WPC RMS. 150 dollars for 450 watts, SHIPPED! A good buy, that was! 50A Max current draw, and Class A/B to boot!
