2004 cavalier rs problem
Memphisman
Copper - Posts: 161
Posted: December 09, 2007 at 4:31 PM / IP Logged
I'm having an issue with Crmestopper RS830 RS with a GMSL bypass in a 2004 Cavalier. When using the RS, sometimes it will work on the first try, sometimes it will take 2-3 times, and other times it will take 10-15 times to get it to stay running. It seems to acting like the anti-theft is being bypassed. It doesn't matter what the weather or temp is. I tried running it tachless and in tach mode. I've replaced the brain as well as the bypass with the same results. I went as far as checking all my connections for bad solder joints. Luckily I have an understanding customer. Any help would be greatly appreciated.
howmuchlonger
Member - Posts: 12
Posted: December 09, 2007 at 9:50 PM / IP Logged
What do you have activating the bypass?   It could be that you are using the incorrect output to activate the pass lock interface.  Test the output and see when it triggers the bypass.  You could also bypass the passlock system all together w/ a resistor.( after you meassure the resistance value)  across passlock ground to bcm side passlock wire.
Test it w/your meter!!!
Memphisman
Copper - Posts: 161
Posted: December 10, 2007 at 8:51 AM / IP Logged
I'm using the ground out when running wire. I've done alot of these cars and for some reason this one's being stubborn.
sparkie
Platinum - Posts: 2,061
Posted: December 10, 2007 at 6:06 PM / IP Logged
It may be the wiring and not the modules you need to replace. Sometimes the wires at the plugs don't make contact with the pins or you could have a broken wire inside the insulation. I would suggest try replacing the critical circuits that could cause this. Powers. ground, tach, etc., until you find the problem.
sparky
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
