2005 camry door locks
russ lund
Copper - Posts: 188
Posted: December 12, 2007 at 10:34 AM / IP Logged
I just did an install on a 2005 Camry and all went well until I gave it to the customer.The door locks just fine but the R/S remote will not unlock.If I open the drivers door it will lock and unlock just fine. I think I had this problem on a Matrix but I can't remember what the hell I did. Thanks Russ.
BigDog
Twelvoltz
Platinum - Posts: 2,384
Posted: December 12, 2007 at 10:38 AM / IP Logged
Set the unit to double pulse unlock.
russ lund
Copper - Posts: 188
Posted: December 12, 2007 at 11:05 AM / IP Logged
Yeah I have set it to double pluse to no avail.
BigDog
Chris Luongo
Platinum - Posts: 3,746
Posted: December 12, 2007 at 11:21 AM / IP Logged
Would help a lot if you mentioned the product you installed, and how/where you connected locks.
OhioMike1101
Silver - Posts: 343
Posted: December 12, 2007 at 11:33 AM / IP Logged
probably set up with the child locks
South Side Audio
2501 S. High St
Columbus, OH 43207
russ lund
Copper - Posts: 188
Posted: December 12, 2007 at 12:21 PM / IP Logged
Sorry gang.The unit is a scytek Galaxy 2000.I used  the regular lock and un lock from the unit.The vehicle isn't set for child lock.
BigDog
tedmond
Gold - Posts: 4,610
Posted: December 12, 2007 at 2:25 PM / IP Logged
double pulse to unlock. the thing with camry is one pulse disarms the alarm and other pulse opens the locks.
JWorm
Platinum - Posts: 2,208
Posted: December 12, 2007 at 2:28 PM / IP Logged
Did you use these wires for lock/unlock?
POWER LOCK      BLUE / YELLOW (-B) See NOTE *2      IN DRIVERS KICK PANEL or 20-PIN PLUG, BOTTOM of FUSE BOX
POWER UNLOCK      BLUE (-) See NOTE *2 (REQUIRES DOUBLE PULSE)      IN DRIVERS KICK PANEL or BECU, TOP PLUG, PIN 22
NOTE *2 THE LOCK AND UNLOCK WIRES WILL ONLY TEST WHEN TURNING THE KEY IN THE DRIVERS DOOR KEY CYLINDER.
russ lund
Copper - Posts: 188
Posted: December 12, 2007 at 2:31 PM / IP Logged
There is no blue wire in that harness,I used the key in the drivers door to find the wires.But why does the lock and unlock work when the dorr is open?
BigDog
tedmond
Gold - Posts: 4,610
Posted: December 12, 2007 at 3:44 PM / IP Logged
Power Locks - Blue / YELLOW (-) located @ BOTTOM of  DKP. Located in a 16 Pin BLUE connector.
Power Unlock - Blue (-) located @  DKP Third plug from the bottom. Located in a 20 Pin BLUE connector.
not sure why the locks would not work when door is closed. make sure u connected everything properly and make sure u didnt snip any wires in the process.
