05 honda accord, viper 5002
eeh1025
Copper - Posts: 113
Posted: December 13, 2007 at 4:24 PM / IP Logged
Hi there i have an o5 honda accord coupe and im installing a viper 5002 system, my question is the door locks what type of system is it, and what wires do i hook up to,
thanks alot
tedmond
Gold - Posts: 4,610
Posted: December 13, 2007 at 4:38 PM / IP Logged
honda door locks are Negative trigger or known as Type B
Lock - Pink/Black (-) located under dash @ MICU*. Pin 25 in a Green plug
Unlock - Pink/Blue (-) located under dash @ MICU*. Pin 9 in a Green plug
*MICU is part of underdash relayfuse box.  The plugs are hard to get to since they sit on the left hand side edge.
good luck
eeh1025
Copper - Posts: 113
Posted: December 13, 2007 at 5:19 PM / IP Logged
Hi there i have an 05 Honda Accord coupe, could you mount the unit behind the door panel,I mean you have your 12v constant 12v keyed door locks, etc. Would it hurt anything to mount it there?
JWorm
Platinum - Posts: 2,208
Posted: December 13, 2007 at 5:47 PM / IP Logged
Do you have an EX or LX? This is one of the few cars where it makes a difference.
eeh1025
Copper - Posts: 113
Posted: December 13, 2007 at 5:56 PM / IP Logged
its is an EX
tedmond
Gold - Posts: 4,610
Posted: December 13, 2007 at 5:57 PM / IP Logged
umm i dont think thats the brightest idea. ur limited to space. plus u have to run wires back to the door molex to kick panel. doing that alone will kick u in th ebutt. it will take really long. just hide it up in ur dash and tape it up/loom it good. doesnt matter if u wired it and hid it, as long as the theif wants to cut the power to ur alarm, he will easily.
howmuchlonger
Member - Posts: 12
Posted: December 13, 2007 at 6:50 PM / IP Logged
I wouldn't think about it.  There is way too much moisture in the door.
Test it w/your meter!!!
dre187
Copper - Posts: 129
Posted: December 13, 2007 at 8:24 PM / IP Logged
everytime you close your door, you would be abusing the unit pretty bad too
Chris Luongo
Platinum - Posts: 3,746
Posted: December 13, 2007 at 10:21 PM / IP Logged
I did that once in an older Civic.
It worked out perfectly, and the car never came back.
But, when I reached the point where I was halfway done, and it was too late to turn back, I started to regret it.......there were quite a few wires that had to be run back inside the car.
Posted: December 14, 2007 at 12:39 AM / IP Logged
Bit like climbing Everest :-  'cause it's there. If yu've got so much time, come and help me.
