ccs 100 compatability
jdbocade
Posted: May 08, 2009 at 1:29 PM / IP Logged
Is the Audiovox ccs-100 aftermarket cruise control compatible with my 2006 Dodge Caravan? The van is equipped with a 3.3 litre v6 and has an automatic transmission. If it is compatible where can I find the wiring diagrams for the 2006 Caravan?
M-GoBlue
nikko0213
Member - Posts: 9
Posted: May 30, 2009 at 8:16 PM / IP Logged
M-GoBlue
Only way you can use that CCS-100 in your vehicle is by putting magnets on it.  The reason why you have to use that is cause the VSS speed pulse on that vehicle is 38,600 pulses and the CCS100 only goes to 8000 pulses.  If you decide to go with the CCS100 you will have to set it up for 2000 pulses cause of the magnets so switch 1&2 will be set off.  Make sure you put switch 3 on.  If you dont want to use a CCS100 there's anothor cruise you can use it's made by Rostra.  Below I listed the parts you will need.
250-1316 (Cruise Unit)
250-4369(Signal Generator)
250-4184(Throttle Adaptor)
250-3421(Dash Mount Switch)
Here's a link to there website:  http://rostra.com/cruise-control.htm
Hope this helps you out.
Nick
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
