1990 Acura legend cruise control
maclamb
Posted: November 09, 2003 at 8:51 PM / IP Logged
Hi,
I'm new to this forum. I just purchased a 1990 Acura legend. It's cruise control system will "turn on" - but will not engage when I prtess the set button on the steering wheel control. I have checked the fuse and it is OK
Any ideas where to start testing?
thanks
You are not your car
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 12:59 PM / IP Logged
Check to make sure the Mechanical side of cruise is operating normally, Its located next to throttle cable. Start there and let me know?!?
Gary Kline
MECP Master Technician
softail
Posted: December 28, 2003 at 10:42 PM / IP Logged
actually i have the same problem on my 1990 acura integra the switch lites up , i tested the criuse control actuator and it works fine i've tested the switches im my steering wheel and still nothing any help would be appreciated thanks
Geeque
Silver - Posts: 310
Posted: January 03, 2004 at 10:19 AM / IP Logged
Check the connection at the transmission for a faulty vss solenoid or try checking vacuum lines for air leaks.
Gary Kline
