flip down monitor, 2001 honda civic
adix5689
Member - Posts: 24
Posted: February 01, 2006 at 4:58 PM / IP Logged
This weekend I am going to install a 7inch alpine tmx-r700 monitor in my 2001 honda civic . My question is where do I put the mouniting plate.  The monitor does not come with one first of all. I did some research online and found two different ways of doing it. One way was to glue a piece of 3/4 inch plywood to the cars roof and screw the monitor to the plywood. The other way was to sandwhich a piece of plywood between the headliner and the monitor. I want  to do it the right way with out putting holes in the cars roof.
blufab
Copper - Posts: 62
Posted: February 01, 2006 at 6:10 PM / IP Logged
Mount it to the headliner. If you want it to be secure you are probaly gonna have to use screws, just like if you wanted to mount a ceiling console.
adix5689
Member - Posts: 24
Posted: February 01, 2006 at 7:20 PM / IP Logged
I can't screw it directly to the headliner since the alpine monitor will have a gap betwwenn the monitor and the headliner.
mustangfoo
Silver - Posts: 371
Posted: February 01, 2006 at 8:33 PM / IP Logged
Well did you ever try ebay???? Here is one mounting plate, just look around you are bound to find one cheap like this!!!
http:///.com/Alpine-TMX-R705-TMX-R680-Tan-Overhaed-Console-Nice_W0QQitemZ5860728559QQcategoryZ48605QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
auex
Platinum - Posts: 5,041
Posted: February 01, 2006 at 8:57 PM / IP Logged
Do you have a sun/moon roof?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
adix5689
Member - Posts: 24
Posted: February 01, 2006 at 9:34 PM / IP Logged
I do not have a sunroof.  There is a universal trim ring for it. The only one I can find is on ebay and is tan.
mustangfoo
Silver - Posts: 371
Posted: February 01, 2006 at 10:07 PM / IP Logged
It may be tan, but you can modify  it, paint it, use your imagination.  If you scratch one up you can create some good stuff, but just don't do what my uncle does a lot and mickey mouse stuff.  Make it look nice.
mustangfoo
Silver - Posts: 371
Posted: February 01, 2006 at 10:08 PM / IP Logged
o0o one more thing I know a place near me that they sell wholesale and used mobile electronic stuff and might go down there this weekend, I could take a look and see if they have one cheap if you want, let me know before Friday.
thugpac445
Posted: February 09, 2006 at 5:22 PM / IP Logged
i have the same problem but my problem is installing the tmx-r680a to cadillac deville 96 please tellme how you fix the problem thank you i thin to cut and then put it in whit no base
bigpac445
adix5689
Member - Posts: 24
Posted: February 09, 2006 at 7:47 PM / IP Logged
You could put it in with no base. The headliner area that you mount the monitor to would have to be perfectly flat. In my car the headliner is not perfectly flat.
