amp power cable problems
jonsmith210210
Posted: July 31, 2008 at 7:20 PM / IP Logged
I just bought a new Dodge Ram 2008 Q cab 1500. I want to install an amp, but I can’t figure out how to run the 12 volt power lead. I do not want to drill any holes in my new truck. Does anyone have any suggestions on the best place to run the power cable? I am running two amps of this line and need to be directly connected to the battery. I think I can go in behind the front passenger side kick panel, but I can’t figure out how to remove it. Any advice would be much appreciated.
Jon Smith
still_walkin
Silver - Posts: 644
Posted: August 03, 2008 at 11:12 AM / IP Logged
Those new cars hide the screws look for circles bout a 1/4 wide the usually covers for the screws. Also find a wire that is going through your firewall and your can put your power wire through the firewall if you can find one you might have to drill so look hard.
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
kickz l7
Member - Posts: 15
Posted: August 04, 2008 at 12:27 AM / IP Logged
Just find were some wires are going may be like a big thing of rubber just carefully put a little slice in it and put the wire through
