need assistance choosing a sub amp
sciullo779
Member - Posts: 12
Posted: November 10, 2009 at 10:25 PM / IP Logged
im seriously starting to pull my hair out deciding on these amps, i read the choosing an amp post but i still dont know
i have 2 powerbass M-10's in a ported box. each sub is rated at 300Wrms@4ohm 600W@4ohm max single voice coil
they currently are running in a parallel at 600wrms@2ohm 1200W max
and when finding wattage from fuses is it the TOTAL watt count like if the amp has 2x60A fuses you use 120A?
im debating on these amps
this ones a little underpowered but its on the safe side i guess, its perfect but it is a class a/b and im not sure if its putting out what they say it is.........
http://www......com/item_13492_MB+Quart+DSC+1000.1.html
higher powered model-same price- i kinda like this one because i can expand my system but i dont want to blow my subs before im ready to upgrade and its a class d monoblock
http://www.online/CarAu..._DSC15001.aspx
not sure about PG
http://www.online/CarAu...d_RSd6001.aspx
Soundstream STL1.600D 600wrms@2ohm
i really like this amp alot but i heard soundstream went downhill recently
http://www.woofersetc.com/p7757/STL1600D--Soundstream-monoblock-600-Watt-RMS-D-Class-Stealth-Power-Amplifier.htm
JL Audio J2 500.1 500wrms@2ohm
more then likely pushes more then what its rated for. idk its a jl
http://www......com/item_20627_JL+Audio+J2+500.1+-J2500.1-.html
Alpine MRP-M500 500wrms@2ohm
just found this one keeping it in the picture
http://www.crutchfield.com/s_500MRPM500/Alpine-MRP-M500.html?tp=115
thanks for the help guys
and if you wanna suggest something try to keep it under $220
ragsports
Copper - Posts: 192
Posted: November 11, 2009 at 8:11 PM / IP Logged
The JL Audio and the Alpine are going to be your best choices out of the amps listed, Look into JBL as well.
Garbage in EQUALS Garbage out...
sciullo779
Member - Posts: 12
Posted: November 11, 2009 at 9:05 PM / IP Logged
well i mean the subs are rated for a max of 600wrms in, will the jl 500.1 make more then 500wrms possibly?
will i really notice a difference of 100wrms?
and as far as i know my vehicle almost never puts out over 13.8v and the jl is rated at 14.4
sciullo779
Member - Posts: 12
Posted: November 11, 2009 at 9:14 PM / IP Logged
sorry for the double post
what about these
what about JBL GTO7001 (is this too much power?)
http://www......com/item_12248_JBL+GTO7001.html
GTO601.1II - JBL 600 Watt Mono Amplifier
http://www.woofersetc.com/p235/GTO6011II--JBL-600-Watt-Mono-Amplifier.htm
ragsports
Copper - Posts: 192
Posted: November 12, 2009 at 8:39 AM / IP Logged
Either of the JBL amps will work. As long as you read the sticky on how to set your gains properly you will have no problem with the amp being rated higher than the woofer. The higher powered amp may give you room to upgrade down the road. As of the 100 watt difference there will be very little or no gain in performance from 500rms to 600 rms. With that being said the JL is most likely underated, i would say it is actually more in the ballpark of 550rms.
sciullo779
Member - Posts: 12
Posted: November 12, 2009 at 12:45 PM / IP Logged
ok, well then its a toss up between the jbl's, the JL, and the alpine mrp 500
or i could push it a little price wise and go for the 620wrms@2ohm ARC mono amp =]
http://www.woofersetc.com/p6859/FD-6001--ARC-Audio-1-Channel-620-Watt-Amplifier.htm
so try to give me a what i should shoot for a #1 amp and a #2 amp
blackcivichatch
Copper - Posts: 229
Posted: November 12, 2009 at 12:51 PM / IP Logged
My vote goes to Alpine. But if you want to spend the extra, i would do the JL
UNLABELED Custom Car Club President
pcana11
Copper - Posts: 116
Posted: November 12, 2009 at 8:05 PM / IP Logged
i have the alpine mrp 500 and its bad ass. very tough
blackcivichatch
Copper - Posts: 229
Posted: November 12, 2009 at 9:30 PM / IP Logged
Thats wut I like to hear considering I just ordered an M1000 need assistance choosing a sub amp -- posted image.
sciullo779
Member - Posts: 12
Posted: November 15, 2009 at 6:11 PM / IP Logged
i was looking at power ratings and their all rated at around 14.4-14.5
so if my car only ever sees 13.8v i could more then likely go with a 700-750Wrms amp right? because most amps are slightly overrated, and with less voltage make less power
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
